Old 10-26-2015, 02:58 PM   #1
Portsmouth , Rhode Island
Worried About Floor Rot
Considering pulling the trigger on a new Flying Cloud 19 - is it a realistic concern that I might need to replace/repair the floor within 10 years time? Even if I do regular inspections for leaks? This thread has made me nervous. Give it to me straight!
kala1300 is offline   Reply With Quote
Old 10-26-2015, 03:33 PM   #2
ottawa (greely) , Ontario
All you can do is do maintenance ,and inspections to try and delay the floor rot issue. It's simple when wood gets wet ,it rots , the airstream design and or materials needs to change to eliminate this problem that's been going on since airstream was invented, I own a 2015 and was waxing it yesterday and noticed the caulking around the roof vent and antenna base had cracks in it , today I remouved the old caulking and resealed it. Airstreams are a lot of work! Even 2015 's , I've attached some pictures the close up photos show a crack in the caulking .
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 10-26-2015, 03:35 PM   #3
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Keep up the maintenance.
Floors rot because checks for leaks and maintenance don't occur. Floor rot is totally preventable. It's not going to happen because it leaked one time in the rain. But if you let a leak persist for 10 years.... well duh.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-26-2015, 03:37 PM   #4
Here is a second picture of antenna base. With poor caulking!
Don
Old 10-26-2015, 03:48 PM   #5
Oh here is another spot airstream forgot to put caulking on the rivet heads under the front window,these are were the front plastic ,tinted ,glass protectors are fastened to, nice !�� they did it on three others but missed these two rivets on one mount,
Sorry photo is sideways !
Don
Old 10-26-2015, 05:32 PM   #6
65CV's Avatar
Western , Massachusetts
You may want to do a little research on SealTech leak testing. If your dealer does it, maybe you can get a couple of annual tests thrown in as part of the deal.
Down the road, if you are a do-it-yourselfer, search for Hillbilly leak test on this forum.
65CV is offline   Reply With Quote
Old 10-26-2015, 06:00 PM   #7
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Don
AS management must have had a whip on the tech who applied the chalk on the vent and antenna. What a rushed sloppy job.
Kelvin
Old 10-26-2015, 06:22 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Set up a regular inspection schedule to check for leaks, inspect caulking, and inspect and treat panel edges and rivets and shell fittings for corrosion (CorrosionX is a good product), touch up nicks and scratches with a clear acrylic pen. Treat the underbody steel as well. I would suggest quarterly in your area based on our experience. You could back that up with a SealTech Leak Test every few years by an RV shop.
The only way to know if your plywood subfloor is wet without disassembly is by probing through the vinyl floor into the plywood subfloor with a moisture detection meter. Sharpen the probes to make it easy and leave little trace. Probe the perimeter of the interior floor all around, especially under windows, door, and awning supports. If its wet, find and seal the leak. Then be sure the floor dries out.
This is a simple and effective meter made by Sonin, the probe is on the end of wires so it's ideal to get into the corners. About $30.
Your subfloor cannot rot unless it's wet, and that can be prevented.
Doug and Cheryl
Old 10-26-2015, 08:11 PM   #9
Kelvin
Kelvin. I think a three year old put the caulking on , all the newer airstreams are done this way! My 2012 was the same!
Don
Old 10-26-2015, 08:36 PM   #10
dkottum's Avatar
The caulking ain't pretty but it probably won't leak for awhile, unlike a finely laid bead that will be good a season or two. They've been heaping this stuff on the top and underside of the Airstream for some time, our 2012 has it. You do need a stepladder to see it, and I suppose that's the reasoning.
Troublesome is the unsealed exterior pop rivets. Water can enter the trailer in great quantities through those little holes when going down the road in a downpour, and there is a negative air pressure on the inside of the Airstream. Like sucking a soda through a straw.
Add this to your regular inspection and repair schedule. Seal the hole and all around the rivet. You'll find them at the rock guards, awning support arms, model emblems, maybe other.
Doug and Cheryl
Old 10-26-2015, 08:49 PM   #11
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I would highly recommend sealing everything on the roof with Eternabond Alumibond... EternaBond | AlumiBond / A-Seal, A Seal, Aluminum Faced
You won't have to worry about roof leaks for a long time.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 10-26-2015, 09:09 PM   #12
N/A , N/A
Thanks for the info. A couple of Q's:
1) How long would the tape last? How often do you need to do this?
2) If/when you need to replace the tape, does it come off easily? Or do you just apply another tape on top of the existing one?
Thanks!
rostam is offline   Reply With Quote
Old 10-26-2015, 09:32 PM   #13
PaulnGina's Avatar
Good Ol' , USA
Thanks!
I have had the Eternabond Alumibond tape on our 1987 Avion for almost 2 years (2 hot summers, one cold winter) and it looks as good as the day I applied it. From Eternabond's site:
"How long does EternaBond® last? Because EternaBond® is made using MicroSealant Technology®, depending on surrounding conditions, EternaBond® has an estimated life expectancy of 18-35 years if applied correctly. The "pre-activated" shelf life of EternaBond®, stored correctly, is 5 years!"
I don't have any more life expectancy information than that, but as sticky as the stuff is, I can't imagine it NOT lasting a long time.
I'll see if I can find any info about removal.
1987 Avion 34W
Old 10-26-2015, 09:45 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
get some Captain Tolley's Creeping Crack Cure.
Peace and Blessings..
Channing
WBCCI# 30676
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
Worried! wander'n Member Introductions 9 05-06-2007 04:24 PM
Worried, help! Walt Stanton Member Introductions 8 04-07-2006 07:30 AM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
Ok Now I'm Worried! Opinions please! 59toaster Our Community 11 10-15-2003 09:00 AM
