Old 06-17-2012, 10:13 AM   #57
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Originally Posted by CrawfordGene View Post
Speaking of airplanes, we were on the way to Alaska and my wife was outside. A guy comes up to her and points out all the dimples in the skin around the rivets. He says he worked for many years on aircraft assembly and those dimples are a result of the rivet gun be set too high and that should not happen if the riveter knows his job.
Gene
What, I though AS only hired the best of the best.
They charge like they do.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-18-2012, 09:01 PM   #58
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Gene
If the dimple was consistent all the way around I would agree. If it is only on one side, it is bad technique.
Michelle TAC MT-0
Sarah, Snowball
Old 06-19-2012, 01:14 PM   #59
USN Avionics Tech QA Insp
LarryGlover's Avatar
Morristown (Gatlinburg, Pigeon Forge area) , Tennessee
Images: 8
Originally Posted by CMSmith View Post
So is there a better insulation to use once a floor is replaced so moisture does not get trapped against the frame?
I'm doing a frame-off floor replace on my 1965 Streamline (an airstream copy), and I have decided to use a spray in foam insulation that is water pepellant and helps seal all cracks . I would imagine you could also use a bedliner material such as rhinoliner or line-x liner as this would coat the bottom of your wood floors as well as the frame and provide temperature and noise insulation as well. Batt insulation is used from the factory because it is inexpensive and quick to install with no delay in build time due to drying or curing times that are required by spray in insulations.
LarryGlover is offline   Reply With Quote
