Old 05-01-2009, 10:10 PM   #1
2007 27' Safari FB SE
Any where the wind blows me , California
Why is this to difficult to fix?
Photo #1 This is what my floor looked like after the first "repair". Photo # 2 This is what it looks like after the 2nd "repair". Is this within industry standards??
ID:	79513   Click image for larger version
jaojamjab is offline   Reply With Quote
Old 05-01-2009, 11:32 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Looks the same to me?
Hi, I don't see much, if any, difference between the two pictures. I think there might be a dent or knot hole in the plywood floor under the vinyl. If this is the case, the vinyl will need to be lifted or removed and the dent or hole filled with bondo or wood filler.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-02-2009, 06:58 AM   #3
Yes, definitely appears to be a void in the subfloor underneath the vinyl. The only way to repair it is to fill that hole.
Old 05-02-2009, 07:02 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
..another quality build out of Jackson Center......how do you put soft rolled vinyl on a bad subfloor? Are there few at the factory floor that use their heads? No one saw a funky floor and said, you know we should patch that plywood and sand it before rolling the floor over it.......
Must be the same guy that ate his McDonald's breakfast sandwich, balled up the wrapper and shoved it in my umbilical opening in the front inside of my trailer.
Old 05-02-2009, 10:26 AM   #5
Uberphotos's Avatar
1968 22' Safari
Kalamazoo , Michigan
Did this come from Jackson Center looking like this?
How long have you had the Airstream?
I would demand a proper repair...you paid enough for the trailer, you should expect excellent quality. If you wanted a crap trailer, you would have bought a SOB.
'68 Safari Land Yacht, Double
Check out my blog... http://ssairstream.blogspot.com/
Uberphotos is offline   Reply With Quote
Old 05-03-2009, 12:23 AM   #6
Second repair was done in Jackson Center
The floor didn't look like this when I got the trailer. It had a slight bump in the floor noted when I bought the trailer. I took it to C & G trailer for repair under warranty and this is what I got. That's not all they messed up. I complained to Jim Parrett then decided to take it to the factory recently to fix and it still looks the same. Jim insists it looks good. I can't find anyone in California that is a designated repair facility that is competent. (Inland RV Excluded) I'm getting ready to take legal action.
Old 05-03-2009, 12:27 AM   #7
Maybe the same guy worked on my trailer because I found a shop rag in mine
Old 05-03-2009, 05:28 AM   #8
lynn's Avatar
Did anyone give you a cause for the spot in the lino? Could something have been dropped on it?
lynn is offline   Reply With Quote
Old 05-03-2009, 07:09 AM   #9
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Stop complaining and put an area rug over it. Sorry I was channeling Air Stream customer service for a moment.
It is not right and I suspect the entire floor covering has to be replaced and the void filled.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 05-03-2009, 07:35 AM   #10
2007 25' Classic
Hydes
Looks like it needs to be repalced and the void filled and sanded. I called Jackson Center for new tail light lenses for my 07 Classic after months of failed attempts to get them for my dealer and was told to just " buy them from a truck stop"
craftsman is offline   Reply With Quote
Old 05-03-2009, 07:49 AM   #11
Aluminut
2004 25' Safari
. , Illinois
If it is what I think it is, the whole floor would need to come up. This would mean that most if not all the cabinetry would need to come out, unless you wanted them to roll another sheet over the old and have some sort of edge lip installed. Even then there could still be a slight imperfection that may be noticeable. What you have does not look like something was dropped on it. It looks to me that the plywood had a defect, the mindless line worker still rolled the floor over it, then as it settled it became more and more noticeable which would most likely not have been the case at first as it was first rolled.
To be honest, between your floor and your front tearing sheet metal, I would say you should be concerned and upset. Just the floor, I'd be less angst (not carefree), but the front skin tearing, the floor....I'm just waiting to hear about what happens next...
I would encourage you to post your exp for your 2007 here:
http://www.airforums.com/forums/f142...ity-21553.html
Old 05-03-2009, 10:13 AM   #12
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I definetly agree that after spending the big bucks that you shouldn't have to accept that. However, Airstream should care enough about keeping good workmanship standards a priority. In lieu of 'repairing' it again and increasing the chance of more further gaffs they should offer some adjustment to you. At least then when visitors to your coach spot the dent you can have some compensation to support your 'defense'. An area rug would help. My wife has rugs all over our coach for comfort. I don't like them mostly because I am the one who has to shake them out. But for now I don't complain because it lowers my priority to replace the floor covering in our 43 year old coach.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-03-2009, 10:20 AM   #13
Aluminut
2004 25' Safari
. , Illinois
Looks like more flooring issues on another fairly new Airstream too:
http://www.airforums.com/forums/f44/...tml#post693594
Old 05-03-2009, 11:20 AM   #14
lynn's Avatar
Has either repair center pulled the vinyl back? Did you let them know the repairs were not acceptable before you left?
windows difficult to open wolf146 Off Topic Forum 5 04-19-2009 03:51 PM
Difficult to remove AC? 71_safari Furnaces, Heaters, Fireplaces & Air Conditioning 5 07-02-2004 07:04 PM
Ready to Roll a difficult read... Safari Tim Our Community 1 01-20-2004 12:09 PM
Difficult Hot Water Lighting JLD Water Heaters, Filters & Pumps 3 02-23-2003 03:48 PM
How difficult would it be to add... Chuck Waste Systems, Tanks & Totes 5 01-28-2003 10:06 AM
