Old 05-19-2004, 12:14 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
why bend the bolts?
anyone care to explain to me why they bend the elevator bolts that hold the floor down to the frame? now how am I supposed to get them out?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-19-2004, 01:08 PM   #2
Images: 55
Chuck,
That was Airstreams "locknut". They were bent to prevent the nut from vibrating off. The only way to easily get them off is to cut them off.
Tripp
Tripp is offline   Reply With Quote
Old 05-19-2004, 01:17 PM   #3
Images: 59
Chuck,
I suspect it was cheaper and easier than trying to put a lockwasher or using a nylon locknut.
Here's the method I found easiest, after trying to grind them off and cut then off.
1. Mark the position of the frame and crossmembers.
2. Cut through the floor with a circular saw just outside the frame members.
3. Use a Sawzall to slice horizontally through the remaining plywood and screws.
You can see it here: http://www.airforums.com/forum...9&postcount=79
and http://www.airforums.com/forum...0&postcount=80
Old 05-19-2004, 02:19 PM   #4
Morning Dew's Avatar
Send a message via AIM to Morning Dew
where are these bolts? i'm trying to remove the rear floor in mine. i've got everything out of the bathroom and i'm left staring at a bare floor. there were 4 machine screws that i was able to remove with a screwdriver but thats all i've found. the floor still seems attached to the frame but i can't tell what holding it down.
Brian Travnicek
31' Sovereign Land Yacht
Pulled by a 2001 Silver Dodge
2500 Truck with Cummins Diesel Power and a 4.10 rear end.
Morning Dew is offline   Reply With Quote
Old 05-19-2004, 02:32 PM   #5
Images: 55
Brian,
They run along the frame rails and crossmembers. The bolts go through the floor and the frame and have nuts underneath. If you have your bellypan off in the rear, you can see the bolts/nuts from under the trailer along the various frame members.
Tripp
Old 05-19-2004, 02:39 PM   #6
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
This is what it looks like from underneath...
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 05-19-2004, 02:49 PM   #7
ok, but shouldn't the heads of these bolts be on top of the plywood or recessed? all i've got are the 4 machine screws.
Brian Travnicek
Old 05-19-2004, 02:54 PM   #8
Images: 55
Brian,
Yes, you should have recessed heads visible about every 12-18". If you only have 4 machine screws, it is possible that your floor was repaired (incorrectly) sometime in the past. It is imperative that the floor be through bolted to the frame as the floor is part of the monocoque design of the trailer.
Tripp
Old 05-19-2004, 03:05 PM   #9
Over59's Avatar
Putnam , Connecticut
Images: 37
Aren't there some in the walls between the shells also?
Over59 is offline   Reply With Quote
Old 05-19-2004, 03:10 PM   #10
Images: 55
Paul,
Yes there are. They hold the "c" channel to the floor. The body is then riveted to the channel and the "ribs" of the body are through bolted to the floor as well.
Tripp
Step Support Bolts. . . JeffandSuzanne 1998 Excella 1000 16 08-05-2013 10:34 PM
Toilet bolts uwe Sinks, Showers & Toilets 3 12-16-2003 08:51 PM
Why check your vintage U bolts Deluxe21 Axles 8 11-04-2003 03:27 PM
Step Support Bolts. . . JeffandSuzanne Steps 3 06-18-2003 08:40 AM
lug bolts Chas Axles 3 02-18-2003 09:55 PM
