Old 10-13-2011, 08:02 PM   #1
2005 28' Safari S/O
Powell Butte , Oregon
Whole new frame
Does anyone know if the frame on a 1968 31 ft Internationalwas built flat or was it welded up on a jig with a small arch built into it? Heavy long truck trailers have a very pronounced arch to them so that when thay are loaded with cargo they end up flat. Did Airstream do this or did they use a perfectly flat frame jig? Mine is pretty rusty and needs a makeover.
How much shoould a 31ft bare shell weigh?
sawdawg1 is offline   Reply With Quote
Old 10-13-2011, 09:22 PM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The shell is stiff enough, and the frame limber enough, that the frame conforms to the shell. Bare, the frame in my driveway sags an inch or more aft of the axles with the hitch jack set to level with above axles - that tells me the axle bracket, errr, frame, was fabricated flat.
I'd guess my 73 27' outer shell layer with windows and hatches weighs in at #500.
Old 10-17-2011, 02:41 PM   #3
Airstream has never uplifted a frame.
Frame Failure dmm9623 Repairing/Replacing Floor &/or Frame 9 08-12-2011 10:03 AM
'69 Overlander frame repair colin57 Repairing/Replacing Floor &/or Frame 6 04-25-2011 10:45 AM
frame reinforcement - rear end separation silversafari Repairing/Replacing Floor &/or Frame 1 03-17-2011 10:16 AM
1965 Caravel Frame funhouse 1965 Caravel 0 03-01-2011 09:12 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
