Old 12-16-2007, 07:10 PM   #1
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Where to purchase 5/8" plywood?
Hi Folks,
I'm replacing some rotted flooring at the door and frig vent area.
It is only 12" wide a couple feet long.
I have been to Lowes.
They do not sell 5/8" plywood only in particle board.
I purchased a 3/4" 2 x 4 sheet of oak plywood.
Will this work at the door?
Greg
ID:	50997   Click image for larger version
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 12-16-2007, 07:25 PM   #2
I love Airstreams...
leefields's Avatar
1989 29' Land Yacht
Haines City , Florida
Talking worked for me....
i replaced both front and rear 6 foot sections with marine 3/4 i bought from Home Depot....seems Lowes would have same.....maybe it is a regional thing...
lee
1953 Spartan Mansion
Ram 3500 DRW LB SuperCrew
PCS Professional Coach
AIR# 6366
leefields is offline   Reply With Quote
Old 12-16-2007, 07:53 PM   #3
Darol Ingalls's Avatar
Go to a "real" lumber yard. Lots of cabinet grade 5/8" out there. Darol
Darol Ingalls is offline   Reply With Quote
Old 12-16-2007, 08:55 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Hi yo' Silver. Hope you're enjoying the Forums! 3/4" is probably more than was in your Overlander. A lot of these were built with half inch -- wear & drying make them seem closer to 7/16" by now. 5/8" isn't far off the mark. I found some fairly solid veneer layers in a 19/32" underlayment at a local lumber yard that worked -- thicker than original. You'll have trouble deviating from thickness if you attempt to slide it in all areas of the perimeter. Janet's Husband & I had various conversations that don't match your situation exactly here and here. Try this thread too.
5 meter Langford Nahanni
Old 12-16-2007, 09:49 PM   #5
cosmos's Avatar
1965 17' Caravel
Birmingham , Alabama
Images: 8
5/8 plywood
I bought 5/8 sanded b/c ulx (exterior grade glue) plywood from Lowes.
As someone pointed out, not all stores carry all thicknesses. I contacted Lowes at the phone number on their website They told me I can order it on line and have them ship it free of charge to my local store for me to pick up.
So that is my fall-back plan if I need more plywood and the local store runs out. I found the 5/8 b/c ulx plywood to be reasonably good and has less voids in it than I expected. Just be sure to stay away from the "sheathing", it has too many voids. By the way, while I keep referring to 5/8 as the thickness, it is actually sold as 19/32 because they sand off 1/32.
cosmos is offline   Reply With Quote
Old 12-17-2007, 07:29 AM   #6
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
5/8 " plywood
Greg,
I second going to a "real" lumber yard, that's where I got mine no problem. I didn't need a whole sheet so they sold me a small leftover section. If you need even more specialized selection then check out this place The Wurth Wood Group They have a store in High Point.
TB
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'09 Silverado --- Big Bertha
Adoptee -- '78 Argosy 24' Moho -- Big Girl
tinbender is offline   Reply With Quote
Old 12-17-2007, 07:33 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Always support your local lumber yard!
62 tradewind Floor width "plywood" scoxx30 Repairing/Replacing Floor &/or Frame 37 01-06-2006 06:43 PM
Looking for 5mm or 3/16" plywood fitzjo1 Cabinets, Counter Tops & Furnishings 6 03-10-2004 08:54 PM
