Old 05-24-2012, 10:51 PM   #15
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
I have done some checking locally and neither Home Depot nor Lowe's nor any other chain building supply stores carry 5/8" (19/32") plywood. However, one of the few remaining local building material stores, Star Lumber, carries nominal 5/8" exterior plywood in both AC (about $34/sheet) and AB (about $44/sheet) and both are decent looking. It's interesting about what you can and can't get and where.
Although my trailer has 5/8" OSB floors, I'm planning to use 3/4" plywood as it's a better thickness match to the adjacent OSB that is still in fairly "good" shape except for some swelling due to moisture and the fact that it's sitting on some fiberglass insulation. I plan to plane the perimeter that goes into the C channel.
Steve
Steve Bryant is offline   Reply With Quote
Old 05-24-2012, 11:03 PM   #16
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Hate to sounds like a broken record but check with smaller advertising 'sign' workshops and see where they get their signboard plywood from. I went that way with true 3/4" 49x99" MDO (medium density overlay) and am very happy with it - for about the same money as the AB you mentioned.
Old 05-31-2012, 03:48 PM   #17
rogerdodger's Avatar
Fresno/Clovis , California
Originally Posted by cameront120 View Post
5/8" is a very common plywood thickness. Try going to a real lumber yard for it. They should have offcuts for sale. If you can't find 5/8", buy 1/2" and some floor levelling compound to make up the difference.
Thank you, I did find a "REAL" lumber yard, had to buy a 4X8, hopefully I won't need it all. Will have it for other projects.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 05-31-2012, 04:36 PM   #18
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I hate buying 4 x 8 sheets when I only need a little, but eventually it all gets used.
Gene
