Old 12-16-2007, 07:10 PM   #1
Profile:  1967 26' Overlander
Winston Salem , North Carolina
Where to purchase 5/8" plywood?
Hi Folks,
I'm replacing some rotted flooring at the door and frig vent area.
It is only 12" wide a couple feet long.
I have been to Lowes.
They do not sell 5/8" plywood only in particle board.
I purchased a 3/4" 2 x 4 sheet of oak plywood.
Will this work at the door?
Greg
ID:	50997  Click image for larger version
Greg
Winston Salem, NC
WBCCI 5218,
1967 Overlander International.
FTC 15771
1979 Avion 30ft rear bath
Silverwanabe is offline   Reply With Quote
Old 12-16-2007, 07:25 PM   #2
I love Airstreams...
Commercial Vendor
leefields's Avatar
Profile:  1989 29' Land Yacht
Haines City , Florida
Talking worked for me....
i replaced both front and rear 6 foot sections with marine 3/4 i bought from Home Depot....seems Lowes would have same.....maybe it is a regional thing...
lee
1989 Squarestream
F350 DRW LB SuperCrew
www.pcsflorida.us
leefields is offline   Reply With Quote
Old 12-16-2007, 07:53 PM   #3
Darol Ingalls's Avatar
Profile:
Go to a "real" lumber yard. Lots of cabinet grade 5/8" out there. Darol
Darol Ingalls is offline   Reply With Quote
Old 12-16-2007, 08:55 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hi yo' Silver. Hope you're enjoying the Forums! 3/4" is probably more than was in your Overlander. A lot of these were built with half inch -- wear & drying make them seem closer to 7/16" by now. 5/8" isn't far off the mark. I found some fairly solid veneer layers in a 19/32" underlayment at a local lumber yard that worked -- thicker than original. You'll have trouble deviating from thickness if you attempt to slide it in all areas of the perimeter. Janet's Husband & I had various conversations that don't match your situation exactly here and here. Try this thread too.
Old 12-16-2007, 09:49 PM   #5
cosmos's Avatar
Profile:  1965 17' Caravel
pelham , Alabama
5/8 plywood
I bought 5/8 sanded b/c ulx (exterior grade glue) plywood from Lowes.
As someone pointed out, not all stores carry all thicknesses. I contacted Lowes at the phone number on their website They told me I can order it on line and have them ship it free of charge to my local store for me to pick up.
So that is my fall-back plan if I need more plywood and the local store runs out. I found the 5/8 b/c ulx plywood to be reasonably good and has less voids in it than I expected. Just be sure to stay away from the "sheathing", it has too many voids. By the way, while I keep referring to 5/8 as the thickness, it is actually sold as 19/32 because they sand off 1/32.
cosmos is offline   Reply With Quote
Old 12-17-2007, 07:29 AM   #6
tinbender's Avatar
Profile:  2001 16' Bambi
1972 23' Safari
Piedmont Region , North Carolina
5/8 " plywood
Greg,
I second going to a "real" lumber yard, that's where I got mine no problem. I didn't need a whole sheet so they sold me a small leftover section. If you need even more specialized selection then check out this place The Wurth Wood Group They have a store in High Point.
TB
If you believe that "For Sale" sign that says "No Leaks", count the one in your head........
tinbender is offline   Reply With Quote
Old 12-17-2007, 07:33 AM   #7
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 11
Always support your local lumber yard!
Pingbacks are On
62 tradewind Floor width "plywood" scoxx30 Repairing/Replacing Floor &/or Frame 37 01-06-2006 06:43 PM
Hubcap search -- looking for "dog bowl" or "baby moon" hub caps yukionna For Sale & Wanted 5 07-26-2004 04:44 PM
Looking for 5mm or 3/16" plywood fitzjo1 Cabinets, Counter Tops & Furnishings 6 03-10-2004 08:54 PM
SEO by vBSEO 3.1.0
