Old 02-03-2012, 06:44 PM   #1
aluminitus's Avatar
1962 24' Tradewind
Nappanee , Indiana
Where is the 'soul' of a vintage trailer? And how bad is too bad for a frame?
While removing the subfloor today, we made some unhappy discoveries: Penetrating Rust.
Of the 3 crossmembers we can see, two and a half need to be replaced!
At what point do we throw up our hands and a) buy a nice tent or b)buy a new frame?
Since I live in RV manufacturing land and have connections to the underworld of RV parts, buying a new frame isn't out of the question. By the time you figure in costs to have new metal welded into the frame, having it sandblasted, painted with POR-15... All this adds up fast, making it almost as economical just to buy a new frame.
Which begs the question: Where is the "soul" of a vintage trailer located? In the axle? That's being replaced. The interior skins? Gone. Original lights? In the trash. The frame? Begging for its life. Exterior skin? Two panels will be replaced. At what point do I stop owning a "Vintage Airstream" and just have a very expensive pile of scrap metal?
All that to say, at what point should I give up on the old frame and opt for new? Help!
aluminitus is offline   Reply With Quote
Old 02-03-2012, 06:59 PM   #2
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
Bismarck , North Dakota
Looks familiar
Once we got our Albatross torn apart and had several people take a look at it, we were to the point of either a) crying...especially me... b) sobbing....me...c) foul language....not me...mostly. The time and money it would have cost to try to repair what was there was too much and we opted for a new frame from front to back. Added in all new outriggers as well. The only things that we ended up being able to salvage were the steps, bumper, and tongue.
Yours looks a lot like ours was and I wish you luck on getting that fixed up. I think starting over was easier than trying to piece and cut and weld and fix. I don't know beyond our one AS so far so others can add a lot more here than I can.
Sandy
ND10CentCan is offline   Reply With Quote
Old 02-03-2012, 08:12 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1962 16' Bambi
1967 22' Safari
Avonton , Ontario
While removing the subfloor today, we made some unhappy discoveries: Penetrating Rust.............. At what point do I stop owning a "Vintage Airstream" and just have a very expensive pile of scrap metal?
Looks like you'r already there.
I've done a couple of these, and I find it overpowering to think of the whole job. Just start with the idea of finishing it in bites, one job at a time. That way you can celabrate finishing over and over. It also helps if you have another trailer that you can use while working on the rebuild. Keeps you motivated to get finished.
Doug
VAC - TAC ON-1
62 Bambi
60 Ambassador Int.
67 Safari
72-20' Argosy
68 Tradewind
Shacksman is online now   Reply With Quote
Old 02-03-2012, 08:16 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1998 30' Limited
1947 22' Liner
Valley View , Texas
Images: 47
Your OK
If that is yours in the image gallery....with the body above the frame....your OK. The body looks great and the frame is fully exposed. A welder can fix the rust problem where needed and if you POR you should not sandblast. It is called paint over rust after all. Then have fun putting it together like you want it.....with your own concessions to modernization. Wiring is a breeze and with the new PEX type plumbing you can do that too. Insulation goes quick and is no more difficult that cut and paste. Take a deep breath....your almost there.
Old 02-03-2012, 08:44 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1962 16' Bambi
1967 22' Safari
Avonton , Ontario
Just saw this in the classified section. Might be just what you need.
Airstream Safari Frame For Sale - Airstream Trailer Classifieds - Airstreams Trailers For Sale
Doug
VAC - TAC ON-1
62 Bambi
60 Ambassador Int.
67 Safari
72-20' Argosy
68 Tradewind
Old 02-03-2012, 08:50 PM   #6
Martinez , California
I may have shared this before ...
A few years ago I was in a boat repair shop and I saw a ChrisCraft runabout being restored. The shop had replaced every single piece of wood except the transom. I mentioned this to the shop owner and he said that he was using the transom as a guide to getting the new parts to fit, but when he was done he would replace the transom also. That would mean that there wouldn't be so much as a screw left from the original boat. I asked "Wouldn't it have been easier to just get the blueprint and build it from scratch?" He looked at me quizzically and finally said "Well, then it wouldn't be a ChrisCraft."
Mr.Bill is offline   Reply With Quote
Old 02-03-2012, 08:57 PM   #7
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
The term, as pointed out to me on these forums, is Lincoln's Axe. Look it up.
FC7039 is offline   Reply With Quote
Old 02-03-2012, 09:27 PM   #8
safari62's Avatar
1962 22' Safari
Vacationland , Maine
Images: 43
as others have suggested...
The cross members are thin to begin with and now is the time to fish or cut bait. I have no idea what that means since I do not fish, but replacing the cross members is not a big job. If you are not familar with metal work find friendly local welder to do the installation. Prep the job yourself to save money and sawall and grind away for a day. After doing this watching the welder work will add to the excitement.
While you are at it beef them up with slighty heavier stock and plan for gray tanks if they are part of the plan. Make sure it is all leveled and square before adding the new metal.
It will be ready for another fifty years.
And like Abe said, make sure ye tools are sharp and always wear eye and ear protection!
The hard part is over, except for those interior end pieces and all the cabinetry......oh... and putting the body back on.
Gary
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
tAc ME-2
safari62 is offline   Reply With Quote
Old 02-03-2012, 10:41 PM   #9
Certifiable
mistral blue's Avatar
Your vintage Airstream's soul is located within the breath of life that you breathe into it.
Your Airstream Spirit nourishes your trailer's soul and vice-versa.
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
mistral blue is offline   Reply With Quote
Old 02-04-2012, 06:11 AM   #10
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 92
I am the “Soul Proprietor” of my trailer. I think Airstreams have an aura. The owner provides the soul. Whether you patch it back to life, or start anew, it will still have soul.
1977 Sovereign a.k.a. Gort
Updated-Designs
Zolatone- An anti depressant sold to Airstream owners to help them cope with interior painting problems.
Sneakinup is offline   Reply With Quote
Old 02-04-2012, 08:23 AM   #11
New Smyrna Beach , Florida
Reminds me of the story my father always told. It was how a man smoked the same pipe for 30 years. Had 25 new stems and 30 new bowls.
My numbers are probably wrong but you get the gist.
Alunamin is offline   Reply With Quote
Old 02-04-2012, 08:30 AM   #12
touched
62overlander's Avatar
1948 22' Liner
Catonsville , Maryland
I have a 1961 Scotty that falls right into this same situation. The frame is about all that is original at this point.
Frank Yensan The Airstreamer's Club USA-1 "we're dead serious about having fun"
http://annalumanum.blogspot.com/http://frankstrailerworksblog.blogspot.com/
www.frankstrailerworks.com
62overlander is offline   Reply With Quote
Old 02-04-2012, 09:28 AM   #13
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Keep as much of the trailer as you can while still building it to your design. The spirit and soul come from the stories and occupants, the rest is just aluminum and wood. The rusty frame isn't much of a problem, replace pieces or the complete frame. imagine what the ford pickup in your first picture will look like after 50 years?
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 02-04-2012, 10:03 AM   #14
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
complete 1940 Ford 5 window coupe
Bob Drake is reproducing a 1940 Ford coupe body-complete. He also trade marked the expression: "Everybody wants a '40". This thread should stand as a reminder to those who want a vintage trailer. Find a title, and have one built-it will take less time, and save money.
wmarsha is online now   Reply With Quote
