Doing a shell off floor replacement of a
1963 Bambi
I have the replacement plywood cut and the next step will be to drill the holes for the elevator bolts. Once all the drilling is complete, I will coat the plywood with either marine grade enamel or marine grade epoxy.
some of the bolts will pass through the plywood and the new galvanized sheet metal wheel well covers. Before the floor is permanently bolted back in, I want to use an adhesive/ sealer to attach and seal between the wheel well covers and the frame.
What adhesive/sealer do those that have been down this path reccomend ?
