Old 08-23-2011, 09:35 AM   #15
Tool Hoarder
West , California
Originally Posted by Aktundra View Post
Excited and over whelmed with how much I have to learn. I keep telling myself . . .at least its only a 16' Bambi, . . .at least it's only a 16'.....
Still trying to sort through the info in the forum. After researching where to start (floor and frame), I started trying to list the tools I was going to need. A forum search produced mostly expired links to on-line sources but I think I am wading through things.
It looks like the first tool I am going to need, is a rivet remover. Since interior and exterior are different forums. Perhaps this is as good a place as any to post a tool question.
Can the same rivet remover be used for exterior buck rivets (drop the belly pan) as interior blind rivets (remove inner panels to release the floor/frame)? Suggested sources for a rivet remover?
I used both of these tools one for blind "pop" rivets and one for solid rivets
Aircraft Tool Supply | RIVET REMOVAL TOOL | 1341A
Aircraft Tool Supply | BLIND RIVET REMOVAL TOOL | 1341S
They make rivet removal really simple. Also I would buy some extra drill bits from VTS or Inland RV cause you will break them. Dont get the regular 1/8" or 3/16" from local hardware stores. Fastanal is also a great place to get rivets stainless steel bolts nuts screws etc. Check out my thread and you will see whats in store for you. I am picking up my axles in a bit hope to have pics up tonite!!
marzboy is offline   Reply With Quote
Old 08-23-2011, 09:08 PM   #16
Anchorage , Alaska
thanks mimiandrews, I will get a #30.
I was thinking I would start with the interior blind rivits since they have that nice centering hole.
do you know if the factory blind rivets are the same shaft diameter as the factory buck rivets?
Aktundra is offline   Reply With Quote
Old 08-23-2011, 10:13 PM   #17
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Everything I have drilled out in our '66 Safari has been a 1/8" diameter rivet shaft. The only thing we've had to do in that department has been a few interior pop rivets and a few rivets on top where we replaced the air conditioner. In other words, not much experience, because we were lucky on the condition of our trailer.
Olympic rivets have a 3/16" diameter shaft, but the head is the same size as the 1/8" bucked rivets. That might take a #20 drill. It definitely takes that to drill the correct size to install them. I haven't taken any of those out yet, just put them in.
I think the factory bucked rivets in the Airstream are aircraft AN470A4-? The 4 in the rivet number is the diameter in 32nds of an inch so a 4 is 1/8". The dash number that I don't know is the length of the rivet in 16ths.
The interior rivets I've found are plain old big box store pop rivets.
Old 08-24-2011, 11:55 AM   #18
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Not sure if anyone has mentioned it, but Cleco's make life a heck of a lot easier too. One of the best investments I made in taking apart and reassembling the trailer. They are especially useful in securing the endcaps and ceiling skins while you are drilling out rivets, or else the stresses from the weight of the freed section will try to shear the drill bit and cause damage or at least a safety risk.
And remember, this forum runs on pictures, so make sure to add lots of those.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
S Tardis :: 1963 Airstream Bambi CaddyGrn Airstream Registry Discussions 1 07-24-2013 09:43 PM
1963 Bambi Tires highcotton 1961 - 1963 Bambi 0 08-18-2011 07:58 PM
What's the "wet weight" of a 1963 Bambi ? Aktundra 1961 - 1963 Bambi 3 04-20-2011 01:35 AM
1963 Airstream Bambi 16' very good w orig Zolotone eBay Watch Airstreams on eBay 0 03-20-2011 06:10 PM
1963 Airstream Safari 22'. Pre Bambi. Own the Road. eBay Watch Airstreams on eBay 0 02-19-2011 10:20 AM
