Old 03-22-2012, 07:44 AM   #1
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
What years did AS use OSB?
Went on the factory tour at Jackson Center yesterday. They are using T&G plywood on the floor and I forgot to ask when they went back to plywood. Looks to be 5/8" thick.
They are also spraying some sort of black material on the plywood about a foot in from the edge. Nobody seemed to know what the product is called other than it was some sort of anti-wicking product.
Flynavy is offline   Reply With Quote
Old 03-22-2012, 09:51 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Pahaska had a 2002 22' CCD when they first came out. The first appearance of OSB was for this model IIRC. And I don't think it was used on many other coaches -- somebody might chime in on that. Here's a few pics of his OSB and narrative when he put down his cork floor.
I think it was something like 2004 before they realized they had a big problem and discontinued OSB. Could be off a little on that. Do I recall at the end of the OSB experiment they even started building 22' CCDs with a membrane between the frame and floor and no belly pan?
5 meter Langford Nahanni
Old 03-22-2012, 10:50 AM   #3
1974 Argosy 20
Kooskia , Idaho
There was a lengthy thread on the subject. You might want to do a search rather than covering it all again.
What is this camper? roadtrip232 Vintage Kin 59 01-12-2013 02:58 PM
What did a Classic Motorhome Cost New? Keyair Classic Motorhomes 42 08-12-2012 06:39 PM
Investigating used AS Bambi Engie Member Introductions 70 04-27-2012 09:01 PM
Noob looking at a 31' '77 AS 270win 1974 - 1979 Sovereign 61 03-23-2012 10:13 AM
