Old 07-29-2015, 02:45 PM   #1
1971 27' Overlander
zeeland , Michigan
What to use between frame and floor
I thought I read here that something should be used between the frame and the new floor, but I can't find it back. I know the only thing between it before was the old insulation, and that's not going back. If anyone has an idea on this I would appreciate hearing it. Thanks for your time
binnendyk is offline   Reply With Quote
Old 07-29-2015, 03:09 PM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I use white foam sill gasket stuck to the frame to separate it from the plywood.
Name:	100_6063 (640x480).jpg
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 07-29-2015, 03:13 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I believe the factory now uses something like reflectex, like foil bubble wrap!
Old 07-29-2015, 05:01 PM   #4
1971 27' Overlander
zeeland , Michigan
Would it be good to use both the sill foam and the reflectix together, or would that be overkill. Does the bubble wrap collapse as soon as the floor is tightened down? Is this done to eliminate squeaks or is there another reason? Thanks again
Old 07-29-2015, 05:09 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
They claim great r value. I see a benefit as the pink fluffy stuff absorbs water, bubble wrap does not. Yes it gets squished where there is contact with the frame. If it was up to me, I'd first staple up a full length/width sheet of tyvek house wrap, then the reflectex. The tyvek is one way breathable.
Old 07-31-2015, 06:46 AM   #6
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
The main reason is to keep the metal frame from touching the wood floor. Moisture coming through the plywood will cause the metal to slowly start to rust. When you take one apart you can see the rust damage along the frame rails and fasteners rusted off. Originally Airstream just let the fiberglass squeeze between the frame and floor which held water and caused the floor to rot.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 07-31-2015, 08:50 AM   #7
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
When I put mine back together, I pondered this question a while, and after wasting a bunch of time dithering over it, concluded that anything you put between the floor and the frame runs the risk of compressing or disintegrating over time and leaving a gap, movement, and squeaking in the floor. Any vapor barrier you install on the underside of the floor is just as likely to trap moisture against the plywood as it is to keep the moisture out. Instead, I put three coats of poly on the underside before installation and called it good. The R value of the radiant barrier films becomes practically nothing as you eliminate the air gap, so sandwiched between a frame rail and the floor, I can't believe that the film would provide any noticeable effect.
This is another one of those aspects that are easy to overthink/overengineer, but at the end of the day, even the most insulated floor will be worth little when your aluminum trailer is riddled with vent holes and windows which will bleed heat.
good luck
Insulation between floor and belly pan. What to use? 68Glbtrotter Repairing/Replacing Floor &/or Frame 32 12-29-2013 04:15 PM
Is there corrosion between the steel frame and aluminum floor in Minuets? timzog All Argosy Trailers 10 06-17-2012 02:52 PM
Gap between floor & frame at the rear end ASNomads Repairing/Replacing Floor &/or Frame 6 01-30-2012 04:09 PM
ProDex between new floor and frame? Comments? Wabbiteer Repairing/Replacing Floor &/or Frame 3 10-18-2011 05:27 PM
Between new floor and frame? surfpod Repairing/Replacing Floor &/or Frame 11 07-01-2011 06:21 AM
