Choices for under floor insulation and ventilation
Malcolm,
With your floor removal underway, have you made any decisions on how you will insulate and ventilate the under-floor volume as you discussed in thread 11881 about 13 years ago?
My 2001 Bambi has a new uprated Dexter axle, and I need to decide on the insulation/ventilation system to use before replacing the belly pan material. My floor and frame are in good shape, but the old fiberglas insulation was completely removed.
I'm considering a 2-in thick rigid foam mounted to the floor with standoffs and formed to allow 3/4in air space, and provide for condensation or water drainage to the bellypan. I likely will plan to use a small grid vent in each floor section bellypan segment, similar to a soffit vent, to assure sufficient drainage while minimizing air flow and blocking insects and vermin from entering.
Any thoughts or considerations you could provide would be welcome.
And best of luck on your restoration project.
Marshall Swartz
2001 19-ft Bambi
2013 Honda Ridgeline RTL
