What is the lifetime of a wooden floor and how to replace it?
I have just bought a 1979 Safari and are changing the interieur. As I pulled out the original carpet I realized, that the floor consists of wood. I wonder, when it is time to replace such a wooden floor? And is it possible to change the floor from the inside?
Your advice is really appreciated by Hans
Replacing the floor is major surgery. If the floor is still in acceptable condition, I would leave it alone. If there are soft spots at the door or in the bathroom, I would replace those sections only.
The floor is fitted into the channel that runs around the trailer. To replace the entire floor means pretty much disassembling the trailer. There have been some threads and some great photos on this forum from a fellow who did just that. It was a major project.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Absent a leak that has caused extensive rot, or termites, or some similar disaster, the floor should last the life of the trailer. Whatever that may be.
John I think understates the seriousness of the surgery to replace a floor. He says major surgery, I say catastrophically-major major surgery! This and total frame replacement would IMHO be the most serious undertakings. Maybe total skin replacement would be tougher, but I'm only imagining.
Also if I am correct the floor is attached to the frame and the shell perimiter-channel is attached to the top of the plywood. I was not aware that the plywood edge was inserted into a channel as well. The narrow perimiter edge of the plywood upon which the shell/channel rests is the key. Unless it was rotted to such a degree that the shell had dropped for great lengths (and even then it could likely be lifted and re-filled with new (treated) "sill" pieces). Any rot or soft spots inside the perimiter can be removed and new sections,plugs,patches,etc. be fit and filled in. That is not to say that those will all be easy.
Today there are epoxys that can be applied and injected into rotten wood to stop the process and restore where removal is not practical.
See www.rotdoctor.com
I doubt the flooring in vintage Airstreams was treated, although I know that treated plywood was available back in the 70's if not earlier. I have also wondered if the flooring is T&G (tounge and grooved) plywood. Not sure that would have been wise however due to the need for a little flexibility during travel.
I have read somewhere on one of the forums or disc. groups that it was marine grade plywood, I have my doubts, but that would be nice too.
Just remember when patching all edges must sit on floor supports or you will have a soft area.
The trailer body lower channels that I have seen sit flat on the floor. The motorhome lower channel wrap around the floor.
To do a total floor replacement you have to pull the body. I would rather replace skins. The floor in my mh was 1/2", I doubt if it was marine, know it wasn't treated (treated would not be real great as it would out gas some pretty nasty stuff and it is indoors), it was not tongue and groove, you are probably right about flex and the tongue or groove splitting out from the movement. Some used OSB instead of plywood.
The floor is made from 5/8” tongue and groove plywood. The aluminum channel is fastened to the floor and to the shell assembly. Notice the bottom slot in the channel. This embraces and protects the edge of the wood floor, giving the joining of the floor to the shell strength and weatherproofing.
The above obviously applies to current builds. I have no idea how far it goes back in time. But yes, at least currently, the edge of the floor is in a slot in the channel and the floor is tongue and groove.
John W. Irwin
Floors in the 60's and 70's models are untreated, exterior grade tongue and groove 5/8" plywood. The tongue and groove was/is glued and stapled from the under side. It has a bazillion staples. It is not going to come apart. In the center wear areas it has an underlayment of 3/8" in for additional support.
Treated plywood is poisonous and a carcinogen. CCA = Copper, chromium, arsenic.
Floor replacement is MAJOR work. I am still working on mine. Unless you have a good covered shop to work on it, it is just not worth the effort. The shop allows you to remove the entire shell from the support frame and replace the whole floor at one time which is the right way to do it.
If you can push an ice pick through the perimeter edges, you have problems. The perimeter is what holds the Airstream together.
You can replace the floor without removing the shell but it will take a lot longer to do the job. I know. Mine started out with just replacing the flooring under the rear bath, which was gone around the entire rear perimeter. This much is completed. As I progressed I decided to replace the front also. I have the frame painted and the pieces cut, ready to go back in with it.
As far as using a water seal, I talked extensively with the engineers at Thompson's. They advised that their product is for exterior use only and not to be used in an enclosed environment.
Marine rot repair products work very well and are a tried and true process for repairing small area's and preventing further damage on wood that is questionable. They are not structurally strong enough to support the shell though.
As far as how long will a plywood floor last...I would say 30-40 years. The center of my floor was as good as it was when it was installed. Very solid. I read your other post about leaks and this is the real destroyer of floors. Everywhere you mentioned as leaking is cause for concern.
If the previous owners of mine would have just fixed the leaks when they occurred, mine would have been solid to this day.
Good Luck and keep us informed on your discoveries.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
Yep John, It is not plywood anymore. My 76 was plywood, but my 85 is
chipboard. I don't know when they started doing this. For the price
you pay for an Airstream, I think this is a shame, but at least they didn't use
particle board.
"It is not plywood anymore... I think this is a shame,"
I have to acknowledge up front that I am not really an expert, but having used both chipboard and plywood in a number of construction projects, I am not sure that chipboard was an inferior product in this application, at least as compared to ordinary plywood, or even exterior grade plywood. I am not wedded to this idea, you understand, but chipboard is wonderfully stable, is not subject to delamination, and really makes a very nice floorsubstrate.
I think I had also read or heard that they now use marine plywood, which is a really superior product. It has no voids, and the glues are very water resistant.
Hallo Hans,
erst nehme dünnen schraubenzieher und steche endlang der wände, um zu festelen ob du weiche stelen findest. Das holz was die benutzen ist absolutes schrot. Mein floor hat keine fünf jahre überlebt. (neues motorhome)
Auch wenn du keine weiche stellen findes, empfiehlt sich
denn boden mit guten dünflüsigen epoxy zu versiegeln, um diese probleme zu verhindern. Fals du fragen zum details hast, bin ich gerne bereit dir zu helfen.
Grüss
alex
