Old 12-06-2006, 08:13 PM   #1
Profile:  acton
what kind of epoxy for floors?
What are you guys using for epoxy when replacing the floors? Ive seen some mentions 2 part epoxys etc.
durans54 is offline   Reply With Quote
Old 12-06-2006, 08:32 PM   #2
jbond's Avatar
Profile:  Shalimar , Florida
Images: 14
Penetrating Epoxy
I've used CPES from the Rot Doctor ( ordered via internet)
http://www.rotdoctor.com/
and GIT ROT from West Marine (bought locally)
http://www.boatbuilding.net/article..../05/01/1241221
Both are thin 2 part epoxies that soak into new wood and seal the wood. Both can also be used to fix dry rotted wood for after it drys the soft wood becomes hard again.
Herb
Wally# 1861
63 Globetrotter Patty 62 Overlander Doc
63 Suburban Andy 63 Overlander Tex
jbond is online now   Reply With Quote
Old 12-06-2006, 08:45 PM   #3
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
are you looking to do a spot or coat the whole floor?
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Defendwally.org
Old 12-06-2006, 09:23 PM   #4
Profile:  acton
at least coat the edges, maybe the whole floor
Old 12-06-2006, 09:56 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
I would say that the adhesive type unfilled two-part epoxy resins can very effectively build a layer on the surface (like boatbuilders' WEST or System Three). Not all epoxies are waterproof but they sure look the same! This type of epoxy minimally penetrates but does a very good job of encapsulating the wood ... up to a point. Whether due to fastener holes or likely eventual wear or anything less than absolute perfect encapsulation, these surface build epoxies will allow water entrance at some point. Trouble builds because the surface layer can hold that water inside the wood for a long time.
A totally different creature are the high-solvent penetrating epoxies that jbond mentions; I heartily agree! They aren't perfect at repairing rotted wood but can stabilize weakened areas. I've also used Rot Doctor in new floor applications near the perimeter and under areas that contain plumbing. Rot Doctor must be used with exceptional ventilation and no flame sources around. Yes, I hedge my bets and then add System Three resin to the top and edge of the floor. This is not a how-to on epoxy. I would recommend that you sign up as a member at www.systemthree.com, which will give you access to their 50 page "The Epoxy Book" as a good primer (downloadable in Adobe Acrobat format).
Epoxy may inhibit adhesion of certain coatings or paints. It is a strong sensitizer and you must keep it off your skin. Do not use power tools on epoxy treated wood unless you use an organic paint spray respirator. To see an example go to www.rockler.com, search on Paint Spray Respirator, item #46383; should also be able to find something like this locally ... at Home Depot?
BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
CanoeStream is online now   Reply With Quote
Old 12-07-2006, 04:41 AM   #6
Silver Mist
LI Pets's Avatar
If your going to do it, do it all. West systems is good but MAS systems is just as good at about 1/3 less in cost. You can get it thru Jamestown distrubutors at a good price.
Just mix two parts 2:1 easier than Wests 5:1 roll it out like paint, the whole floor is 20 minutes.
Wear plastic gloves, drys in about an hour, no oder at all no respirator needed. Actone will clean up.
WBCCI
Defendwally.org
Old 12-07-2006, 10:21 AM   #7
Yes, MAS is another boatbuilder's epoxy of excellent reputation -- but the common surface build epoxies still have their problems. Airstream shell integrity is job number one in maintaining our babies but epoxy is useful insurance for the occasional plumbing problem or shell leak. I will always feel more secure using a penetrating epoxy like Rot Doctor or Gitrot first, then will roughen the surface and apply a surface build product to just the topside and plywood floor edges. I strongly feel that the floor undersides will take care of themselves if you maintain shell/plumbing integrity and the Airstream is not stored around tall grass.
In contrast to the high solvent nature of Rot Doctor or Gitrot, standard epoxies have nothing other than a mild ammonia smell and can be applied without the respiratory protection. Just don't use a power sander, power saw or router on epoxy treated wood without the respirator; heating with tools like these will expose your lungs to the chemicals that we're trying to keep away from skin contact. Once a sensitized rash begins from using epoxy you can never use the product again! I use disposable nitrile gloves for mixing & applying epoxy -- boxes of 100 from the fleet/farm store vet section cost very few dollars.
BobStream
Old 12-31-2006, 09:17 AM   #8
piratesteve's Avatar
Profile:  1958 18' "Footer"
idyllwild , California
Take a good look at the West Systems Epoxy. I disagree that it is hard to mix. You simply get the Pumps that meter both parts. Simply 1 pump from both and you have a proper mixture! I use Denatured Alcohol to clean up (much safer and less hazardous than Acetone, etc.)
If you use plastic containers (like butter tubs) you can just break out the residue and reuse the container.
If you are going to saturate the floor then thin out whatever epoxy you use for the first couple of coats and then the last coat full strength.
There are many good epoxies available to us just be sure it is completely waterproof when cured. A good boat building Epoxy will be engineered to be used for underwater applications.
piratesteve is offline   Reply With Quote
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Epoxy paint used in bath question 74Tradewind Upholstery, Blinds, Walls & Interior Finishes 0 12-12-2002 11:35 AM
What kind of paint for a louver cover for a wall panel heater cindy General Interior Topics 1 09-19-2002 08:38 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Penetrating Epoxy Andy R Repairing/Replacing Floor &/or Frame 8 06-08-2002 06:12 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
