Old 09-28-2003, 08:50 AM   #1
Send a message via Yahoo to Fun-Lovin
What Is Your Tow Rating
For those of us who know what our tow rating is we can help those who are looking for tow vehicles. We can include year, make, model, engine size, and rear end ratio if know.
2003 Ford F-250 Crew Cab, 7.3L turbo diesel, 3.73 rear end.
Convential (receiver) 12,500 and 1,250 tongue with weight distribution or 14,500 on fifth wheel. Specs from ford.
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline   Reply With Quote
Old 09-28-2003, 09:11 AM   #2
joshua32064's Avatar
2003 GMC 1500HD
Vortec V-8 6.0 4x4 Equipped with Quadrasteer - 7,700 pounds
joshua32064 is offline   Reply With Quote
Old 09-28-2003, 10:56 AM   #3
2002 Chevy 2500HD Duramax with Allison Transmission, Extended Cab, 8 foot box, 3.73 axle ratio and 4 X 4.
Maximum Trailer weight 12,000 lbs. Maximum hitch weight 1,500 lbs.
This is the capacity of all 2001-2002 GMC/Chevy 2500HD and 3500 with the Duramax Allison in all configurations whether long or short box, two or four wheel drive, standard, extended, or crew cab. The Gross Combined Weight Rating for these vehicles is 22,000 lbs.
The only towing specs. that change is the maximum fifth-wheel weight. Mine is 15,100 lbs.
A crew cab 4 X 4 long box maximum fifth-wheel weight would be 14,900 lbs and a regular cab long box 4 X 4 would be 15,500 lbs.
All Duramax Allison 2500HD and 3500 trucks are rated to pull 34 foot Airstreams sideways up hill.
et
diesel is offline   Reply With Quote
Old 09-28-2003, 12:58 PM   #4
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
2000 Excursion Limited 4WD V-10
9800 lbs w/ 4WD, 4spd auto, & 3.73 rear end
DOES pull my 34' comfortably.
WILL NOT pull my 34' sideways up a hill.
Old 09-28-2003, 01:03 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
'96 Caprice Classic 5000lbs w/2.93 gears
'96 Impala SS 2500lbs w/3.08 gears (mostly due to cooling)
Eric
Old 09-28-2003, 07:01 PM   #6
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
88 R20 454 FI 3/4 suburban 3.73. As equipped it is rated 9,500k (course the hitch is only rated 9200) Combined GVWR is 16k. WIth 4.10 and a better hitch on the truck it will do 10.5k. Same engine in regular cab truck is rated 12k with 4.10. Pay a towing penelty for the weight of the vehicle.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-28-2003, 07:22 PM   #7
Aluminut
2004 25' Safari
. , Illinois
Hey Toaster.
What do you think my tow rating would be if I placed 3.73s in my 30 spline 8.5 diff (minus the cooling mods I already did)? Right now the car is rated at 5k, but I was hoping adding 3.73s might push me to the 7k mark.
I just got the GM 3.73s, ABS reluctor, Eaton 400lb posi, master rebuild kit, etc.
Eric
Old 09-28-2003, 08:53 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
2003 GMC 2500 Savana Van
Vortec 6000 4.10 axle- 9,900 lbs.
Jack Canavera
STL Mo.
AIR #56
Old 09-29-2003, 02:22 PM   #9
SBS
If I replace the floor with balloons, can I tow a bigger trailer ?
SBS is offline   Reply With Quote
What's your tow vehicle's rating? John Community Polls 112 01-12-2009 11:13 AM
More on tow ratings ipso_facto Tow Vehicles 19 11-16-2004 04:11 PM
Hitch Rating DaveJ Airstream Motorhome Forums 4 09-18-2003 07:29 PM
Tow vehicle rating femuse Our Community 21 03-22-2003 07:16 PM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 10:38 AM
