Old 08-23-2014, 05:22 PM   #1
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
what is this strap on the frame?
We have these on both sides of our frame. What are they, do we need to keep them?
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 08-23-2014, 05:46 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
What was in that area prior to disassembly?
MICHAEL
Old 08-23-2014, 06:50 PM   #3
1967 26' Overlander
Bugtussel , Oklahoma
Yes, you need them. I have a '67 Overlander and that is where the external skins that curve under the frame are attached. Should be some up front too. Mine are rusted out and need to be replaced.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 08-23-2014, 11:01 PM   #4
1967 24' Tradewind
Images: 38
I think the front fell out from rust. These two were there before we took the shell off. There was a long strap going front to back too.
~ Hurley
ingrid
Old 08-26-2014, 09:46 PM   #5
1967 22' Safari
Auburn , Alabama
I'm with Mike they are an anchor point for attaching the skin. Just had mine replaced yesterday - used 1/8"x 2" strips. I have uploaded a scaled drawing that shows where they are on my frame. '67 Safari. If it would help you look it up by my username or I'll send you a copy when I get to my desk tomorrow. Would post but don't have the image in my phone.
Tentmaker is offline   Reply With Quote
Old 08-26-2014, 09:50 PM   #6
1967 22' Safari
Auburn , Alabama
Here it is. Hope it helps. Click image for larger version
Name:	ImageUploadedByAirstream Forums1409111377.828195.jpg
Old 08-26-2014, 10:48 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Great job there, Tentmaker!
I believe that is correct use for the 'strap'.. it is also a handy location for a 'support' under a utility box should you want to add storage there...
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-03-2014, 08:56 PM   #8
1967 24' Tradewind
Images: 38
That helps a LOT. ours doesn't go that far front to back, looks like some fell off or was removed. Do you think it would work if we bolted some on before we permanent ly attached the floor? Our floor is "floating" on the frame right now. Welding would be a big big pain. Is it necessary?
~ Hurley
ingrid
Zip Dee awning pull strap broke ? Davis Awnings 13 12-26-2009 04:57 PM
Part # for LCD mounting plate and strap ericwarren Audio, Video & TV 4 04-16-2009 09:15 PM
Wall mount with strap for lcd tv rochar3 Audio, Video & TV 7 03-16-2009 02:07 AM
Holding tank strap is loose Jim J Waste Systems, Tanks & Totes 9 07-10-2008 09:40 AM
ZipDee pull strap repair Fyrzowt Awnings 5 03-29-2008 01:20 PM
