10-11-2007, 10:51 PM
1966 24' Tradewind
Placerville
What is this 'Bracket' for?
I am putting on new brakes and repacking bearings on our '66 Trade Wind. We have had this coach for a year and a half and this is the first time I have noticed this do-hickey. Anyone know and can tell me what it may be for? As you can see it is mounted on the frame between the axles. There is only one...on the curb side. Thanks.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
10-11-2007, 11:02 PM
1977 31' Sovereign
1992 34' Excella
Salem
, Oregon
Just a guess
I wonder if it is a bracket that held some kind of wheel chock?
Thats my best shot this time of evening.
Wayne
10-11-2007, 11:10 PM
Islay - 63 O.
Montreal
it could be a BBQ holder like McConaughey on his trailer...
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
https://rvcampreview.com
10-11-2007, 11:48 PM
1960 22' Safari
in the wilderness
, The great Mojave Desert
It's an aftermarket curb feeler bracket. Of course I'm guessing.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
10-12-2007, 01:00 AM
1966 24' Tradewind
Placerville
Well......the 'bracket' is on the curb side...
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
10-12-2007, 06:41 AM
I've seen them on several 1966 Tradewinds. These were used extensively before cell phones and GPS recievers.
When going out boondocking, a spring rod is inserted into the bracket. The spring rod scratches a line in the dirt that follows you wherever you go in the wilderness. When your family reports you missing, the authorities just follow the line to your campsite.
It's called the "Hansel & Gretel stick".
10-12-2007, 08:30 AM
Tom, the Uber Disney Fan
2006 30' Safari
Orlando
If it had been on the road side I would have guessed that it was the bracket that held the condensate line from the A/C or the bracket for the fresh water tank drain petcock. My condensate line is located just behind the rear tire and my fresh water drain valve is between the tires, but, again, they are both mounted on the road side.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
10-12-2007, 09:11 AM
1966 24' Tradewind
Placerville
..........really?
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
10-14-2007, 03:53 PM
1972 27' Overlander
Concord
, North Carolina
Judging from the newness of the bolts hoding it on looks added. Personally I like the trailer stick theory. Bob
10-14-2007, 11:11 PM
1966 24' Tradewind
Placerville
Nope, all my plumbing is on the street side and water tanks are up front. We don't have AC just an orginal swamp cooler up top. Thanks.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
10-14-2007, 11:16 PM
1966 24' Tradewind
Placerville
The Hansel and Gretel stick thought is 'cute'. But the bracket for "it" is between the wheels hense the rear wheel would obliterate the scratch on the ground. Those looking for us would just have the tire tracks to follow. Try again.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
10-15-2007, 07:03 AM
The bracket holds a little pointer that can be flipped forward or backwards to point a wheel that needs to be replaced. It's like the flip lever on a propane regulator, you need to manually set the pointer to point at the correct wheel.
If you had the pointer (evidently the PO took it with him), you would set it to point to the left. This indicates that the left wheel is dismounted and being repaired.
It is also a reminder that the wheel needs to be replaced before moving the trailer. So as you are doing your final pre-trip inspection you would see the pointer and know the wheel is missing.
That's my theory, since you proved my Hansel & Gretel story was just hokem.
10-15-2007, 08:18 AM
2006 30' Safari
Orlando
It's an offset stick! The line in the dirt is drawn to the outside of the wheels so that when you look in the right tow mirror you can see the dust being kicked up and know that it is working properly. It is set back so and attached to the frame so that it is firmly seated and doesn't get knocked out of plumb when you hit potholes and bumps in the road. It is also offset so that the stick will also draw a line in the dirt along side any paved roads you might drive down. If you make a left turn on a paved road, the follower knows to look to the left where the line ends to see if there is a turn-off to the left. Simple isn't it?
WBCCI# 4821
10-15-2007, 09:08 AM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
Maybe it's a bracket for a former device that covered the wheels. The previous owner probably had this side exposed to the sun.
10-15-2007, 09:13 AM
INSANITY CENTRAL
1986 32' Excella
Airstream Funeral Coach
Citrus Heights
It's a "locating receptacle". Keeps the jack from slipping off the frame rail. of course the jack must be equipped with a plate with a "locating pin". Kinda like some of the systems used to lift up helo's to place wheels under the skids!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
10-15-2007, 09:24 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
I'm pretty sure it is where the fluxcapacitor used to go. Because fuel for these became hard to come by, and complications stemming from their use, most were ultimately removed. Sadly, no original units are known to exist, and government regulation due to international treaties has effectively forestalled attempts to provide an after market version. I have attached a rare archival image of some of the design team members during testing. This item was useful in providing extra boost on long grades, but had to be used with care.
10-15-2007, 10:23 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
the answer is simple. the bracket was put there to confuse us.
Ricky
