Old 08-25-2008, 10:13 AM   #1
2008 23D Paprika!
2008 23' International CCD
Hollywodd , Florida
Unhappy What is going on with my floor! 2008
New 2008 23 D International Signature Series.
I noticed just two days ago while cleaning the unit that there is something not right with the floor.
There is a line forming under the vinyl floor (like a tube) forming a line going width-sides from the oven to the refrigerator.
Is that normal? was it there before and did not noticed it before? or there is something going on? I con not find the blueprints to see if there is something running under the floor in that location.
I looked under the Airstrieam and underbelly looks intact. It is exactly on top of a piece of 2 x 4 metal from the frame going from the front tire to the other side. There is a space in between the 2 x 4 and the skeen, so I could see that there is nothing going on from the bottom up.
I did notice that the washers that Airstream used to hold the shocks are starting to rot, what a poor choice of material!!
Any suggestions on what to do?
thanks
adotutu
adotutu is offline   Reply With Quote
Old 08-25-2008, 10:26 AM   #2
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
thanks
adotutu
Hi adotutu,
Welcome to the forums.
If it's what I think it is, I would not be alarmed. You state it crosses the width of your unit, so it sounds like a joint line.
I have one in my 27FB, right in the hallway between the bedroom and bathroom. I showed this to my dealer when during the PDI and checkout, and even took a 3 foot level showing the change in plane direction on both sides of this line.
The plywood flooring is joined together at certain points. Unfortunately, its not the best joint I have ever seen. There is not much you can do about it as it is under your flooring material, which runs the whole length and width of your trailer....
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 08-25-2008, 02:01 PM   #3
mustang's Avatar
1999 27' Safari
Kent , Ohio
Welcome adotutu, Boy what a shame. Ya know everything is subject to issues like that, minor but hell when you spend that kind of money you dont expect it to happen. I would take it back and see what they say. Airstream has always been good about customer care / support. I would want it fixed. You bought an "Airstream" not brand X. good luck
mustang is offline   Reply With Quote
Old 08-25-2008, 03:43 PM   #4
2008 23D Paprika!
Hollywodd , Florida
Is it a water line issue or a playwood/rot issue or both?
Old 08-25-2008, 04:40 PM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Neither by the sounds of it. Just the seam of the plywood coming apart and pushing up...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-25-2008, 05:49 PM   #6
mustang's Avatar
1999 27' Safari
Kent , Ohio
ya Thats what I thought to or maybe it got real hot in the trailer and the floorexpanded. Kind of like a carpet that needs restretched
Old 08-26-2008, 08:06 AM   #7
2008 23D Paprika!
Hollywodd , Florida
should I take it back to the dealer? can it be repaired or leave it like it is... thanks from Hollywood Florida
Old 08-26-2008, 08:16 AM   #8
2008 23D Paprika!
Hollywodd , Florida
I just got an e-mail back from Airstream Technical support... (Mustang, Purman & Bambi bandit were right on the mula!!!)
Date: Tue, 26 Aug 2008 10:10:48 -0400
To: adotutu
Subject: RE: Floor question... (contact us from airstream.com)
From your description, it sounds like this is normal. I believe what you are seeing is where two sheets of the wood floor comes together at the cross member. Usually you can see this line.
____________________
Dick
Customer Relations
1-937-596-6111
Old 08-26-2008, 08:27 AM   #9
purman's Avatar
1968 28' Ambassador
Ok, but are they going to fix it... It's a new trailer and I would ask them to fix it... if it were 5-10 years old maybe not but it's not even a year right....
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-28-2008, 09:11 AM   #10
2008 23D Paprika!
Hollywodd , Florida
8 months old. Airstream told me that there is nothing to do.
Old 08-28-2008, 12:00 PM   #11
mustang's Avatar
1999 27' Safari
Kent , Ohio
I would argue that. Even if it ment going to the BBB. I would not take that, what a shame. I have had goold luck with the BBB it takes them awhile but let me tell you companies dont want that on there record. Thats a Damn shame they took that stance. Argue it now, time is not on your side. get it documented. I can almost guarentee they will fix it when they find out they arent messing with with push over. I am intrested in the results after wards. ( Very dis heartning )
2008 31' Classic / 2008 Silverado 2500 4x4 duramax ddarr2 Member Introductions 19 03-09-2010 12:14 PM
2008 Tacoma Burddawg Tow Vehicles 9 05-30-2009 09:19 PM
Towing 2008 19' Bambi with 2008 Toyota Highlander JDBfreeheel Tow Vehicles 1 03-08-2008 09:27 PM
Quartzsite 2008 guy99 On The Road... 11 02-23-2008 10:37 AM
2008 Tundra & 2008 Land Cruiser TV advice Ray Eklund Tow Vehicles 2 02-21-2008 07:49 PM
