02-25-2010, 04:51 PM
2005 16' International CCD
Austin
What insulation did you use under the floor?
I've seen various posts on insulation. Curious to known what seems to be the best long-term solution. Obviously, the old water-absorbing pink stuff is not a good idea.
02-25-2010, 05:13 PM
Princeton
, New Jersey
The advantage to the pink stuff other than ease of installation is it is complete coverage. Any void, hole or edge gap, in an insulating medium is almost a complete lose of insulating value. The pink stuff has no voids.
This level of complete coverage is hard to accomplish with most other types except spray on insulation. The disadvantage of spray on is it will never dry if water is spilled on the floor and get through to the insulation. The disadvantage of using the pink stuff during a rebuild is you can't support it. In manufacturing it is draped over the frame and the floor laid down on it and it is this draping that supports it.
If you cut and fit block insulation you have to seal every seam or glue the complete perimeter of each block to keep air from migrating around the edges.
I don't know but if i were rebuilding and live in Texas I not sure if I would bother to attempt to insulate the floor. The air cell of a well sealed belly pan would almost be enough and not pose any of the problem wet insulation might bring over time.
2004 Excursion 4x4
02-25-2010, 05:24 PM
1968 17' Caravel
Battle Ground
I think the insulation under my floor contributed to it rotting out. I didn't put any insulation under there when I replaced the wood.
Stephanie
02-25-2010, 05:57 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
My Trade Wind has spray foam under it that I think may have been applied by the factory. That stuff is bulletproof.
02-25-2010, 06:24 PM
Many of us opt not to use under floor insulation because of it's water retention characteristics.
Kevin
William C. Swinney
02-25-2010, 06:38 PM
1968 24' Tradewind
Oxford,
, Mississippi
My 68 Trade Wind has spray foam under the belly pan as did Rodney's. At first I thought it was done by a PO, but upon further inspection I think it is original as there is no evidence anywhere that the bellypan has ever been removed from the trailer.
02-25-2010, 07:07 PM
1992 29' Excella
THE RANCH
HOWDY!! Anyone ever tried radiant heating underneath their new flooring? Seems that it might keep your little tootsies mighty happy.....Adios from TEXAS! C&S!!
02-25-2010, 08:21 PM
1964 17' Bambi II
Schererville
, Indiana
I am in the midst of redoing the underbelly of my trailer. I'm using Prodex insulation. There are numerous posts about this type of insulation. The good part is that it's easy to work with & doesn't absorb water. If you search under the word "Prodex", you'll come up with a lot of information about it. Here are a couple of pix of the process that I'm doing:
Becky
1964 Bambi II
1988 Avion 32S
02-25-2010, 08:31 PM
Silver Mist
Riverhead
, New York
I put Prodex on TOP of the floor then pergo.
All the old pink underneath is gone
02-25-2010, 08:42 PM
1963 16' Bambi
Stevens Point
, Wisconsin
I didn't put any insulation in the floor of our trailer either. Fiberglass just gets wet and provides homes for critters. I did consider spray glueing a foil covered bubble wrap but then ,why? In our cold part of the country our homes, (while we have basements) don't have insulation under the floor.
Tim
02-25-2010, 08:43 PM
Remember, Safety Third
Catfish Corners
, Georgia
None. The '73's leak like a sieve in the belly pan by design. I corrected for this and put no insulation back in there in case it leaks again.
02-25-2010, 10:45 PM
Austin
This seems like the best idea yet. Never thought about it on top of the subfloor.
02-25-2010, 11:09 PM
Silver Mist
Riverhead
, New York
This cold winter was the longest test we had, spending almost 3 months with many nites in the 20's and 30's, bare feet were fine.
02-26-2010, 06:46 AM
1967 24' Tradewind
Greenville
, South Carolina
I'm going with 2" rigid foam spaced from the floor bottom with 1" rigid foam.
02-27-2010, 09:43 PM
1970 27' Overlander
ARLINGTON
, TEXAS
Please explain
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
02-28-2010, 05:27 AM
1955 22' Safari
Great Lake State
None, insulation is nothing but a magnet for water contributing to floor rotting. Will be adding stainless steel air vent's to belly pan for proper air ventilation.
toastie
02-28-2010, 06:39 AM
1967 24' Tradewind
Greenville
, South Carolina
Originally Posted by WILDRTEXAS
Please explain
1 " foam spacers similar to what Becky did in post #8, except I will be glueing 2" foam to the spacer instead of Prodex.
03-03-2010, 09:48 AM
1965 17' Caravel
langley
, British Columbia
I didn`t use any insulation under the floor,i had so many mouse runs through the floor and walls,i figured i wasn`t going to give them a second chance,,,i ran the belly pans on my 65 caravel to the two main frames and left the center section open...i used 5/8 t&g fir and sealed the whole underside,,,i want to use cork flooring to finnish off the interior of the floor..does any body know if i should seal the top of the floor before i install the cork,,and what should i seal it with? I used a oil based paint for the bottom,,i`m also going to spray shutz the wheel wells and any where else the water might come in
03-03-2010, 10:56 AM
1977 Argosy 24
Milltown
, Wisconsin
What is the purpose of spacing the foam away from the floor?
03-03-2010, 11:04 AM
1967 24' Tradewind
Greenville
, South Carolina
The foam spacers serve two purposes. Create an air space which improves insulation and also allows for ability of any moisture that might get in, to get out.
