Old 07-13-2018, 08:41 AM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
What comes First?
We are making over a 29' 1992 Excella twin bed. My question is this: Is it better to remove the belly pan and banana wrap prior to removing the floor? In my mind the belly pan and banana wrap should come off first, but I have no experience to base this on.
Here's where we are:
We've removed the interior partition walls, skin and insulation. We've also removed the furnace, above floor ABS drain lines and probably today the Quest supply lines and the water heater. Looking to do the next right thing.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 07-13-2018, 01:41 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Pics! We like pics!
Matt
rugjenkins is offline   Reply With Quote
Old 07-13-2018, 01:45 PM   #3
1969 27' Overlander
Boise , Idaho
Don't remove the bellypan unless there is a reason to do so. Don't remove the floor unless it is rotted, or there is another good reason to do so. Are you replacing or adding tanks? Do you have rear end separation? Is there some other reason you want to both remove the belly and pull up the subfloor?
If there are good reasons to remove both the belly and the floor, I'd probably choose to remove the belly first, since that might make it a little bit easier to get the floor out.
Jamespio is offline   Reply With Quote
Old 07-25-2018, 11:31 AM   #4
1978 Argosy 27
1976 Argosy 26
Elk Rapids , Michigan
The egg, definitely the egg
matthewsx is offline   Reply With Quote
Old 07-25-2018, 11:58 AM   #5
Long Island , New York
Originally Posted by Re-Pete View Post
We are making over a 29' 1992 Excella twin bed. . . .
Your OP is a couple of weeks old, so not sure if this is still an active thread, but you should probably assess the frame/ourtrigger damage, before deciding which way to go.
Check this Love Shack for his innocent thought process in the first few posts, and then possibilities of how far you might have to go:
http://www.airforums.com/forums/f227...ck-183431.html
Gulp!
Good luck,
Peter
PS -- Good advice in this recent post IMO:
Old 07-25-2018, 12:04 PM   #6
PS -- I see you have a later thread, Pete, and many replies in other threads, so I assume that this thread is dead at this point? Confusing IMO.
http://www.airforums.com/forums/f36/...ns-184582.html
Old 07-25-2018, 01:11 PM   #7
2007 22' International CCD
No, the chicken always comes first...that's why the egg never comes at all...
Rich, KE4GNK/AE, Overkill Engineering Dude
recaulking or stripping clear coat... which comes first? sunnynsequim Exterior Restoration Forum 5 04-14-2013 10:40 AM
Which comes first? clemdogmom Member Introductions 20 10-11-2011 07:08 PM
Which Comes First? jlandau Roof Vents, Skylights & Fans 8 03-03-2006 12:20 AM
Now comes the next fun phase: discovery. jpurdy General Motorhome Topics 3 02-16-2003 06:39 PM
