I am putting on new brakes and repacking bearings on our '66 Trade Wind. We have had this coach for a year and a half and this is the first time I have noticed this do-hickey. Anyone know and can tell me what it may be for? As you can see it is mounted on the frame between the axles. There is only one...on the curb side. Thanks.
Neil and Lynn Holman
FreshAir #12407
Attn : IBT
Here's what the free of speech is :
"I may not agree with your ideas but I will fight to death to let you express them"
Voltaire - (rough translation from french)
I've seen them on several 1966 Tradewinds. These were used extensively before cell phones and GPS recievers.
When going out boondocking, a spring rod is inserted into the bracket. The spring rod scratches a line in the dirt that follows you wherever you go in the wilderness. When your family reports you missing, the authorities just follow the line to your campsite.
If it had been on the road side I would have guessed that it was the bracket that held the condensate line from the A/C or the bracket for the fresh water tank drain petcock. My condensate line is located just behind the rear tire and my fresh water drain valve is between the tires, but, again, they are both mounted on the road side.
Family of Disney Fanatics
WBCCI# 4821
It's called the "Hansel & Gretel stick".
..........really?
FreshAir #12407
Nope, all my plumbing is on the street side and water tanks are up front. We don't have AC just an orginal swamp cooler up top. Thanks.
FreshAir #12407
The Hansel and Gretel stick thought is 'cute'. But the bracket for "it" is between the wheels hense the rear wheel would obliterate the scratch on the ground. Those looking for us would just have the tire tracks to follow. Try again.
FreshAir #12407
The bracket holds a little pointer that can be flipped forward or backwards to point a wheel that needs to be replaced. It's like the flip lever on a propane regulator, you need to manually set the pointer to point at the correct wheel.
If you had the pointer (evidently the PO took it with him), you would set it to point to the left. This indicates that the left wheel is dismounted and being repaired.
It is also a reminder that the wheel needs to be replaced before moving the trailer. So as you are doing your final pre-trip inspection you would see the pointer and know the wheel is missing.
That's my theory, since you proved my Hansel & Gretel story was just hokem.
It's an offset stick! The line in the dirt is drawn to the outside of the wheels so that when you look in the right tow mirror you can see the dust being kicked up and know that it is working properly. It is set back so and attached to the frame so that it is firmly seated and doesn't get knocked out of plumb when you hit potholes and bumps in the road. It is also offset so that the stick will also draw a line in the dirt along side any paved roads you might drive down. If you make a left turn on a paved road, the follower knows to look to the left where the line ends to see if there is a turn-off to the left. Simple isn't it?
WBCCI# 4821
