Two rows of these bumps have appeared in my floor, and run across the floor from side to side. The trailer is a 2002 Classic 30 Slide-out. The row of bumps in the picture just below the glint from the overhead light is about two feet to the rear of the door. Another row is about 4 feet further to the rear. My supposition is that it has something to do with the subfloor joints. I do not notice any unusual softness in the area. If I bounce up and down there is a little movement, but I'm a big guy, so I don't think it is abnormal.
The flooring is Allure Trafficmaster.
http://www.homedepot.com/p/TrafficMA...11CAFE0FC262A0
It was put in the trailer by the previous owner, apparently while making several other upgrades. Interestingly enough the installation brochure says it is not for RV use. It is provided in 3-tile blocks and supposed to be installed floating. The 1x3 foot blocks have adhesive which is supposed to be used to stick the blocks together, but it is not supposed to be stuck to the floor. I have not been able to determine exactly how it was installed.
The trailer originally had some kind of a vinyl floor in this area, the bath area and rear bedroom with carpet in the front around the sofa. This flooring is also used in the bedroom area but a different vinyl tile is used in the bath area.
Aside from just watching to see how they progress, any suggestions on what they might be or how to determine what is going on?
Al
