Old 10-08-2018, 09:37 PM   #1
Raminc's Avatar
Wasilla , Alaska
What am I missing
I am the 3rd owner of a Safari 23 and recently noticed while laying on my back inspecting under the rear bumper section that there are several screws with bits of black plastic still connected in a pattern around the black drain pipe leaving the camper. Was this some kind of protective cover that broke off? Are these available in the aftermarket? Maybe someone could share a picture with me of what it looks like. Then I could fab one out of aluminum if they are not available.
Thanks in advance
Raminc is offline   Reply With Quote
Old 10-08-2018, 10:09 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
A picture would help clarify your question. Is this in the area surrounding the pipe's exit from the pan? On mine, there is a slit piece of rubber (a collar) that serves as an air trap to keep the warmer air in the belly and prevent freezing.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 10-08-2018, 10:34 PM   #3
Raminc's Avatar
Wasilla , Alaska
What am I missing
I hope this helps. Maybe you could share a pic of that rubber collar.
Old 10-08-2018, 10:40 PM   #4
Raminc's Avatar
Wasilla , Alaska
What am I missing
Thanks SeeMore
Old 10-08-2018, 10:43 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
No access to a camera at the moment, but I found a similar image (below) on the web. The dump pipe is to the left with the collar. The other is the rubber flap found on both valve stems. In this case , the finger is pointing to the grey tank valve opening.
Sir Tristan
Old 10-08-2018, 10:47 PM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Your second picture post arrived while I was replying. Your particular setup does not match mine. However, it does not appear to be a critical issue. I would not be worried.
Sir Tristan
Aluminum underbelly missing Joe C 2002 - 2005 International 12 11-10-2021 08:55 AM
Missing title, missing VIN in Texas. kristinatx Title, VIN & Registration 33 02-22-2016 08:54 AM
Minor Rust/Paint Missing on Galvanized Parts heyskipper Clearcoat, Exterior Paint & Trim 8 03-04-2003 08:35 AM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
vent fans missing/not working Rog0525 Roof Vents, Skylights & Fans 2 07-02-2002 04:23 PM
