Old 07-16-2016, 03:03 PM   #1
1968 22' Safari
Tulsa , Oklahoma
Well, THIS can't be good...
Actively removing the subfloor on our 68 Safari Land Yacht. Started inside the door and worked backwards, taking out the first three perimeter feet or so, taking stock of rust, rot, etc. , especially near the ends of the outriggers, as I went along. Everything looked OK - surface rust, of course - but when I took out the curbside wheel well, I was disappointed to see what appeared to be a gaping, vertical crack in the main (front to back) beam on the curbside. Kinda like this:
(These photos are sideways.) The hole at the top of the crack was where an elevator bolt was.The crack went from there, across the top of the beam and then downward almost all the way to the bottom of the beam. It's more or less perpendicular to the beam.
First thoughts were:
1) I doubt this is a feature. Probably a bug;
2) I ain't qualified to fix this;
3) If I jack up the beam from the furthest aft point possible, the bending force should close up the gap and I can then get Popeye over here with his big commercial welder and he can stitch it up;
4) Better check out the other side before I call Popeye, so he can fix both sides at the same time, and;
5) So this is rear-end sag?
Any thoughts?
Jay & Lisa
splyb is offline   Reply With Quote
Old 07-16-2016, 03:32 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I have no experience with AS frames, but I do a little welding from time to time with equipt.left over from earlier years when I fixed up old Brit sports cars as a hobby.
I would do just as you suggest - jack it appropriately to close the gap and then weld.
I'd probably weld a doubler a plate over the area too just to be sure! Couldn't hurt!
Small welders such as a 140 or 180 amp Lincoln MIGs are not expensive these days and pretty easy to use. I prefer using solid wire and gas rather than flux core wire when I can - makes for a nice neat weld!
Small MIG's are pretty handy units to have around the house anyway for all kinds of jobs - I seem to still use mine quite often either for myself or friends and neighbours!
I don't think you'll have any problem.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-16-2016, 04:09 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Chris says "ditto" on Wingeezers advice to jack and weld. He said to add the plate on the inside of the frame so it doesn't interfere with the plywood floor on top. The main frame wasn''t cracked on ours, but there were some outriggers that were, and we had to weld and repair. Not hard to do. No one will see it once you seal things back up, so you don't have to be pretty with it.
Probably not due to rear end sag with your size trailer.
Kay
Old 07-16-2016, 04:15 PM   #4
1968 22' Safari
Tulsa , Oklahoma
Yeah, I bought a 120V AC welder a couple years ago at HF, but I'm assuming it won't have enough oomph for a job like this. The doubler plate(s) is/are a good idea. Can I get one that will mimic the shape of the beam?
Old 07-16-2016, 08:19 PM   #5
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
The harbour freight welder will do the job perfectly! The frames are not that thick and the welder can weld up to 3/16 material! I welded my whole frame with one. Replaced outriggers, new tank placement, and re-engineered frame. I 2nd the idea above👍😄
Matt
rugjenkins is offline   Reply With Quote
Old 07-16-2016, 08:22 PM   #6
rugjenkins's Avatar
1975 Argosy 28
Get some angle iron 1/8 x 2 x 3 or 3 1/2
Matt
Old 07-16-2016, 08:31 PM   #7
DFlores's Avatar
1968 22' Safari
I welded a plate to the inside of our frame. Used a Miller 175 Mig welder, while I had the gas and solid wire, my work space was outside, therefore the flux core wire worked better for me because the wind would blow my shielding gas away causing really bad welds.
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 07-16-2016, 08:36 PM   #8
DFlores's Avatar
1968 22' Safari
One other thing to consider, I also have a 68 Safari, I wanted to install a grey water tank between the main framing members. When I put in the reinforcing plates, I just got lucky that there was enough room to squeeze in the tank and the ducting for the furnace running yo bathroom.
You have the opportunity to plan better than I did.
Sent from my iPhone
David & Diane
DFlores
David & Diana
Old 07-17-2016, 09:21 AM   #9
1968 22' Safari
Tulsa , Oklahoma
Great comments
Thanks for the comments and encouragement. May I CAN fix it by myself. Reminds me of the time a friend called and asked me to play in a charity golf tournament. My game was a bit off at the time so, at first, I declined. But then he told me the tournament was for blind and crippled children, and I thought: "Hey! I could win this thing".
I take it the main beams are 1/8"?
Any opinions as to what may have caused this?
Jay & Lisa
Old 07-17-2016, 10:00 AM   #10
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
To me, the break near the top portion looks so smooth it could be cut. And, the edge of vertical portion near the bend looks like the metal is flared outward, like a saw would do. Maybe someone accidentally cut it at the factory?
Alan
Old 07-17-2016, 07:33 PM   #11
Old Sailor
McArthur's Avatar
1983 34' Excella
Victoria , Texas
From having dealt with things like this in the past, I also think that looks more like a cut than a crack. Only some close looking with a magnifying glass would tell. I would investigate because I would be happier if it was a cut.
'82 Excella 34' "AlumaLady"
'06 Ram 2500 Lonestar
"Mollie Bug" The Boston Terrier
WBCCI #4456 - Born to Cruise
McArthur is offline   Reply With Quote
Old 07-18-2016, 07:19 AM   #12
1968 22' Safari
Tulsa , Oklahoma
Me too but. of course, it has to be repaired one way or the other. If it is a cut, it's amazing that the frame hasn't failed in all these years, i.e. the back right end virtually falling off at speed. How is that possible?
Old 07-18-2016, 07:45 AM   #13
1989 34.5' Airstream 345
Hanalei, /Chino Valley , Hawaii / Arizona
First of what a delightfully wicked sense of humor. The golf story had me laughing out loud even the second time I read it.
As to the cause of the broken frame. It is a very clean break if that's what it is.
Any sign of a rack being mounted on the back of the trailer? I'm picturing three or four bikes bouncing around on the back, could possibly do it.
Do you see any thing amiss on the other side? Does the broken part of the frame just hang down taking the bumper with it? Or is it attached further aft.
At any rate some welding and a backup plate as mentioned earlier are in order.
I'd consider putting a plate on the other side too while at it. It does seem a light section beam wall.
Let us know how the repair goes.
Cheers Richard
tevake is offline   Reply With Quote
Old 07-18-2016, 09:43 AM   #14
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Slightly off topic....but relevant?
Years ago when I was involved in building some mobile communications centers I was told by a vehicle up-fitter that one should never weld on a frame. The reason was that the frame members were heat treated and welding would anneal the metal.
These were GM cab-body trucks that were to have shelters mounted to them. Are Airstream frames mild steel so that it is OK to weld, or is there risk of damaging the frame by welding to it? Just curious to know as I may want to add a rear hitch or something in the future.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Well, well, well...you'll never guess what followed us home today! InsideOut Vintage Kin 84 12-23-2015 10:54 AM
A/S Info ? well some good FrankR Our Community 2 05-13-2014 08:33 PM
Refridge light not working, Well it works too good ??? myfirstrv Refrigerators 5 05-07-2008 02:24 PM
Well, Well, Well........ Jim & Susan Off Topic Forum 54 06-12-2005 12:46 PM
