12-20-2011, 09:59 AM
salzburg
, salzburg
Well it's Here - '69 Tradewind
12-20-2011, 11:07 AM
1975 31' Sovereign
1977 23' Safari
Palmer Lake
Wow, you've got a project!
Yes, the front endcap will go out the door. I took mine down and replaced it with aluminum.
Good luck.
Zep
MindsEyePhoto AirstreamDoctor PygmyKayaker
- Corporations are not people
- If you want the public to have an opinion, start the Draft within 60 days of hostilities
- If you are betting other peoples' money, you get a regular salary
12-20-2011, 11:26 AM
1978 29' Ambassador
Morada
If you check out the section on Airstream's web site showing the production line...
You can see that they build the shell first, and then all the interior fixtures are carried through the door for installation...This routine during the 'build' has been a longtime advertized feature of AS's for years...
Yes - the end cap will fit through the door, as will all the cabinets, etc...
Ray & Pat near Lodi, CA
12-20-2011, 04:13 PM
salzburg
, salzburg
yes it certainly is a project! but I will get there, I'm making it into a concession stand so the interior didn't matter to me the rust was a little more than expected but nothing a man and a mig can't sort out! my biggest problem at the moment is the funky smell from the mice and chipmunks that have lived in it over the years, unfortunately i need to wait for a bit of a thaw before i can get it outside to power wash it tomorrow i'm dropping the belly pan and removing the rest of the floor. I think i'll just chop the endcap in half and throw it as i don't think i'll be using it again and it will be easier to manouvre.
12-20-2011, 04:52 PM
1972 29' Ambassador
St. Paul
After pressure washing I used a gas powered leaf blower, the 150mph wind broom kind, to get the dirt dust mud water & cleansers out of all the nooks and crannies, the hidden spaces between ribs and shell etc. When I was finished washing and pushed water around with air it left behind muddy gray tracks, had to rinse it again it was so noticeable. Beware any surviving glass make look on the pressure wash force as a great opportunity to shatter too!
12-21-2011, 09:36 AM
Tool Hoarder
1965 30' Sovereign
West Hills
Congrats Mr Green! That rear end looks a bit messy. Not to worry though mine was much much worse. If you need more pics of what I did I can pm them to you. Just so you know I cut the rear section (about 4 feet) and rebuilt the whole thing. If you are doing that I would do a shell off. Its not a big deal as long as you have good measurements and lots of pictures. Make sure to take note of where the ribs bolt thru the sub floor into the outriggers. If you are doing shell on the floor template will be the channel on the shell itself. Good luck keep the pics comming!
12-21-2011, 10:52 AM
RGates
1968 20' Globetrotter
Thousand Oaks
Nice Project!
I am wrapping up my '68 GT. I posted some pictures of the black water tank area and box surrounding it. It should help you get an idea of what is underneath the rust the rear floor. Go slow and mark your panels for easy reinstall. Always here for a question. Looks like a solid project. Good luck!
Randy Gates
12-21-2011, 11:35 AM
1989 34.5' Airstream 345
Saint Petersburg
Can't wait to see your progress!
Thanks, Derek
12-21-2011, 12:47 PM
1969 27' Overlander
folsom
Good to see another revival like mine (bad shape). I haven't started gutting my overlander yet, but I know my frame will probably look like yours. Keep us posted. Pictures are worth a thoughsand words as everyone knows. Cheers.
12-22-2011, 01:00 AM
salzburg
, salzburg
Thanks all for the replies and encouragement, yesterday i dropped the belly pan and got most of the floor out with a circular saw, man does that yellow foam make lifting the floor hard!! the front of the frame is also not in such good shape the front main rails where the A-frame attaches are holy!! but another chop out and weld in and they should be fine, got myself a new friend who wandered into the barn who is a panel beater with welding skills which is very handy so he's my new welder, i'm still determined to do shell on i think it will be o.k just need to make sure i support the shell properly it will turn out a 40% shell off! as thats about the amount of metal i will cut out!. I will post some more pics tonight once things are a bit cleaner, two weeks ago i helped demolish a 200 year old geusthouse but i think the airstream beats it on the amount of dirt and dust and gross stuff that gets into your hair nose and mouth, can't wait for this part of the build to be done. Randy i have marked the panels which came off but have now decided to put pvc paneling insde which will give the kitchen a nice clean look, the centre strip running front to back will be turquiose along with the room dividers and behind the cook top will be stainless, i really would like the patterned stainless which you see in diners i think it's called sunburst or something like that but i'm thinking fat chance of finding anything like that over here.
Rich.
12-22-2011, 10:06 AM
salzburg
, salzburg
So here's some photos,
Pile of o.m.g from under the belly
how she looks at the moment 20 hours to get it this far!
far side front box beam (well it used to be!!)
now this is a bizzarre one the carriage bolt doesn't sit under the body!
curbside box beam what is relatively a pinhole compared to the other one!!
a bent crossmember i have a set of them (2) just in front of the axles
with the body not lining up i set about to see what isn't square, the front of the main frame is about 5mm narrower than the rest of the frame so will need to sort that out when replacing the metal up front, I have around 6 outriggers that will need replacin and i'll do the bent crossmembers and one at the front which is a bit rusty, I'm going to replace the crossmembers with 12 gauge c channel and then put metal strip between them all to carry the extra weight of the kitchen equipment, the axles will be rated to 7000 pounds so the extra weight from the metal won't matter also i am going to put a 22 mm floor in instead of the original 19mm to help carry the weight over a larger area, i will mill down the outside edges of the board to slip it under the c channel, Randy thanks for the pics of the back end that helped alot,
Rich.
12-22-2011, 10:33 AM
1967 22' Safari
MILAN
Rich.
mrgreen, The interior aluminum skins are an integral part of the monocoupe shell structure. If you replace them with pvc paneling you may have structural issues with the trailer shell. Those panels help stiffen the shell to withstand the stresses on the shell from all the bouncing and flexing the trailer does when being towed. Even if you are only towing it from site to site this could do a lot of damage to your project. If you are converting to a concessions trailer it could still cause all your hard work to be short lived. I think you might want to re-install the panels and just install the pvc paneling over the interior skins. The stainless panels (if in the same thickness as the aluminum ones) should work just fine. Hope this helps you. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
12-22-2011, 11:46 AM
salzburg
, salzburg
That's a good point, but upon thinking about it I think maybe pvc has about the same rigidity when fixed properly to the ribs even if it meant moving up to a 3mm thickness, any thoughts? luckily i didn't make it to the tip on wednesday then!! i will keep the panels just in case but if i go aluminium i will buy some new stuff (the old is a disgusting vinylclad mess) and stick with that throughout and no pvc and i'll use the old ones as templates,
Rich.
12-22-2011, 05:37 PM
1975 31' Sovereign
1977 23' Safari
Palmer Lake
...The interior aluminum skins are an integral part of the monocoupe shell structure. If you replace them with pvc paneling you may have structural issues with the trailer shell. Those panels help stiffen the shell to withstand the stresses on the shell from all the bouncing and flexing the trailer does when being towed. ...
I don't agree, although I certainly thought this was true for the first several years that I owned an Airstream. The wall panels may add a small amount of strength to the shell, but it is minimal. Take a look at how few pop rivets secure the inner walls and it will be apparent that they are not nearly as structural as the outside skins.
Further, in the 70s models (and maybe that includes 68 and 69) the ceiling panel sits in two channel extrusions and are only secured to the ceiling ribs with a few pop rivets at the ends and another six or so (depending on the length of the trailer) in the middle. The fact that the interior skins are one piece along their length does give them significant strength as a beam, so the attachment of the lower inner skin to the C-channel provides substantial vertical stiffness. Still, however, they are not attached with enough rivets to be really structural.
I wouldn't advocate going without interior skins, but they add only a small portion (certainly less than 25%) of the monocoque strength to the shell.
Dissenting opinions welcome, as always.
Zep
| Thread Tools |
| Display Modes |
