right third go at posting this so it's gotta work!!
got my lighting i finished today, it's 24v Led strip, i have 7 metres which only runs 140 watts of power which is great for this fitout as i'm keeping the power consumption under a 16 amp system so i can plug in anywhere.
now to my problem, after getting the lights all finished i decided it was time to clean the interior aluminium of the finger marks but those buggers won't move!!,
i've tried,
Nitro (white spirits)
adhesive remover,
silicon remover,
glass cleaner,
foam cleaner,
the only thing that worked was 3M's fastcut which i don't want to use as i don't want to polish inside and out!! any suggestions from you guys would be much appreciated!!
here's a photo of what i mean
Electric box on the roof!!
heres a photo of the water installation looking back
the walls with the creases will be covered with a splashback, i really wanted the diamond pattern SS which you see in the American Carts but it's 500€ a sheet over here!!, what i'd really like is the SS pressed sunsets you got in the early diners, but there's a good dream! i am geussing i'll be having plain old SS!
here's my water boiler, the only place i could put it unfortunately that flue is going straight through a work bench!! oh well.
Heres a photo looking back to front
Got the door Skinned today (alot more work than i thought) it was a right pain with the curve but after 4 hours it was hung! looks o.k just need to drill the holes for the locks to slide into and i can put that one to bed
