Old 07-09-2013, 04:02 AM   #61
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
what's the cross section of the a/c duct? (nice work, by the way) Is that the only air path from the a/c?
Zep
Zep@Charmedquark.net
Old 07-10-2013, 04:29 AM   #62
salzburg , salzburg
Zep
yes that's the only path,the cross section is 8x1 inch then the vent duct which sits on top is 2x4 inches, i haven't put any drains into it but it is galvanised so it may sweat but shouldn't rust, i'm doing the flue for the instant water heater at the moment which is another piece of metal art! at least a bit of it is flexi tube, the flue itself is 4 1/2 inches accross!! so it's going to use a bit of valuable benchspace i'm afraid
mrgreen is offline   Reply With Quote
Old 08-16-2013, 10:31 AM   #63
salzburg , salzburg
So i made my door and test fitted before i seal up the back end and fit for good
ID:	193319Click image for larger version
ID:	193320Click image for larger version
made myself a new box to hold the gas bottles
done loads which i haven't photographed,
the water is installed,
wiring is complete,
just need to do the gas installation and a few bits and pieces like the window lifters, and the surround for the electric box a drip container for under the aircon ducting as it suffers from condensation! and then it will be onto the fitout itself!!
the light is growing at the end of this long black tunnel!!
Old 08-16-2013, 12:55 PM   #64
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Beautiful work mrgreen.
Interesting Utube. It looks like Pex plumbing lines that I have installed a fair amount of. The fittings that are available here are not nearly as sophisticated as those shown in the utube video.
Dan
Old 08-16-2013, 01:06 PM   #65
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Incredible Work
MrGreen
Just looked at your great thread (and subscribed). Incredible work. Although I am getting used to it I am still often amazed at the level of skills and craftsmanship displayed by the many members of this forum.
There is no down side but REALLY, must you guys and gals set the bar SO high for us basic DIYers. (Tongue in cheek) The inspiration here is incredible it even makes you think you CAN do it after all, and if not hire it out and enjoy it.
Thanks for the inspiration and the pictures. I laughed when I was a early voyeur here on the forum at the constant request for pictures but now I am drawn to the post with pictures also.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-17-2013, 03:47 AM   #66
salzburg , salzburg
Originally Posted by Hittenstiehl View Post
MrGreen
thanks for the vote of confidence!! i am a diy'er myself with the luxury of being able to use a workshop and have on hand a man with 30 years experience building/fitting cabinets in vans and doing conversions to vehicles which helps alot. there are many parts that i am not so happy about ( the interior lining where i hang them with only two people and put creases in them for instance although these will be covered by a splashback!) but you either cover them up or move on and with an overall picture it looks good! at the start i was disappointed when things didn't go to plan but now when i look at the mistakes it's hard to spot them. If i did it all again i'm sure it would go alot faster and be alot better´and i would only do a Bambi!!
Old 08-18-2013, 11:15 AM   #67
Tool Hoarder
West , California
Looking good mr green, glad to see you are still at it!!
marzboy is offline   Reply With Quote
Old 08-20-2013, 11:59 AM   #68
salzburg , salzburg
Help
right third go at posting this so it's gotta work!!
got my lighting i finished today, it's 24v Led strip, i have 7 metres which only runs 140 watts of power which is great for this fitout as i'm keeping the power consumption under a 16 amp system so i can plug in anywhere.
now to my problem, after getting the lights all finished i decided it was time to clean the interior aluminium of the finger marks but those buggers won't move!!,
i've tried,
Nitro (white spirits)
adhesive remover,
silicon remover,
glass cleaner,
foam cleaner,
the only thing that worked was 3M's fastcut which i don't want to use as i don't want to polish inside and out!! any suggestions from you guys would be much appreciated!!
here's a photo of what i mean
Electric box on the roof!!
heres a photo of the water installation looking back
the walls with the creases will be covered with a splashback, i really wanted the diamond pattern SS which you see in the American Carts but it's 500€ a sheet over here!!, what i'd really like is the SS pressed sunsets you got in the early diners, but there's a good dream! i am geussing i'll be having plain old SS!
here's my water boiler, the only place i could put it unfortunately that flue is going straight through a work bench!! oh well.
Heres a photo looking back to front
Got the door Skinned today (alot more work than i thought) it was a right pain with the curve but after 4 hours it was hung! looks o.k just need to drill the holes for the locks to slide into and i can put that one to bed
ID:	193699Click image for larger version
Old 08-20-2013, 01:11 PM   #69
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Zep 40
Not sure if ZEP 40 is available in Europe, but it works well at removing fingerprints from aluminum and stainless steel without leaving streaks.
Lance
Lance M is offline   Reply With Quote
Old 08-23-2013, 08:15 PM   #70
Tool Hoarder
West , California
Very exciting!!!
1963 Tradewind Original Wheel & Tire size?? BurritoWagon 1959-69 Tradewind 20 02-08-2012 02:27 PM
'73 Tradewind on the horizon pxlchk1 1970-79 Tradewind 7 02-05-2012 02:56 PM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
