Old 03-05-2005, 01:18 PM   #1
pinkflamingoes
pinkflamingoes's Avatar
Profile:  1967 24' Tradewind
Alameda , California
Images: 40
welding over/around POR15
OK, I know I should have waited to paint this area with POR15 but I went for it anyway. Now the welder says I should hopefully remove the paint where he has to weld. I have wheeled off as much as I can but it's not all coming off...I'm calling the POR15 company to ask them on Monday, but for now...do I have to get every inch of paint off or can I just maybe chisel the paint off in the corners where he needs to weld, any ideas? I think I'll call him and have him come by and take a look again, but I thought I'd share my pictures and get some feedback...
ID:	10735  Click image for larger version
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 03-05-2005, 01:49 PM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Ingrid,
I know for the welding to work properly you need to have clean, bare metal...in some cases, but I would doubt it in the case of POR 15, you can burn weld thru the paint. But I would go with what you welder wants...
Aaron
WBCCI #2449 AIR #2495
Old 03-05-2005, 02:16 PM   #3
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
One time I was trying to find some kind of sealant for use on my old MG near the exhaust header. So I took all I had and put a bit onto a bit of metal. After letting them dry overnight, I hit each with a propane torch. No joke: nearly all of them burned nicely and dangerously. (Because I had some there, I put blob of standard house caulk into the metal as well. It was leftover from putting bunches of it around the windows of the house. It was also the worst of all: It literally exploded into flames when hit with the propane torch. That was scary!)
Lesson: Be damned careful!
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 03-05-2005, 02:41 PM   #4
markdoane
Profile:  , Minnesota
Images: 59
I don't think you need to remove paint except where the actual weld material will be. You will need to repaint the surrounding area that will get scorched.
A grinder will work better than a wire wheel. I'm sure the welder will have a grinder, so you could wait and let him grind exactly where he will be welding.
Non-contributing deadbeat.
Old 03-05-2005, 03:25 PM   #5
aztlanco
aztlanco's Avatar
Profile:  El Paso , Texas
I agree with Lynn.
The welder should have a torch and he can use it to burn off the paint where he neeeds to weld. I have done this before and it's real easy to remove paint and after the "burn" he can use the wire wheel to clean-up the area. Paint sometimes catches on fire but with the torch, it's easy to put out and by your pictures, it looks like it's all out in the open and nothing near thats conbustible that would burn. Good luck!
Ernie,
'58 Traveler, 18ft. (Freda-a work of art on wheels)
aztlanco is offline   Reply With Quote
Old 03-05-2005, 06:56 PM   #6
pinkflamingoes
Images: 40
thanks, I think I'll grind off the parts. Good advice! I talked to him and he said he'd come by and take a look and see if it's weldable where I have removed paint, which I did today. He will also mark other parts that need paint removed with a pen. I think I'll just do it for him!
ingrid
Old 03-06-2005, 05:34 AM   #7
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Let's see Welder gets $40-$60 an hour...Ingrid gets.....$0-$? an hour....
Good Call!
Aaron
Old 03-06-2005, 07:50 AM   #8
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
ingrid
wow you are making great progress from the time you picked the trade wind from rick!
the area you are having welded is aluminum. i remember the broken door frame when we picked the trailer up from the guy who had it prior to rick.
would it just be easier to remove the remaining piece of the door frame, use it as a pattern? then your door frame would be one piece. your welder should be able to weld it in each corner.
if i recall correctly the sill for the door is just a piece of angle stock.
keep up the good work!
john
you call them ferrets, i call them weasels.
Plastic Welding with PS 30 ALANSD Cabinets, Counter Tops & Furnishings 12 01-21-2007 09:28 PM
POR15 turning green pinkflamingoes Clearcoat, Exterior Paint & Trim 2 01-20-2005 04:09 AM
Solvent welding dmadam Upholstery, Blinds, Walls & Interior Finishes 1 05-14-2004 01:04 PM
Interior Picts Electrical campcollector 1999 - 2004 Bambi 14 04-21-2004 02:09 PM
tear in skin 72tradewind Ribs, Skins & Rivets 14 02-09-2003 07:08 AM
