Old 03-31-2014, 09:44 AM   #1
Scotman's Avatar
1986 25' Sovereign
Lake Alfred , Florida
Welding on frame harm electric systems?
I need to weld some new steel to the main frame rails on my 1986 Sovereign. Is there any potential danger to the 12v or 120v systems from the welder?
Scotman is offline   Reply With Quote
Old 03-31-2014, 10:02 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have never had any problems.. Not on computer equipped cars either. It would be a good idea to lift the battery negative terminal and it is good practice to put the welder ground connection as close to you work area as possibe.
Now the disclaimer. I am strictly an amateur welder. Just because I haven't had problems is no assurance your whole trailer won't disappear in a puff of smoke
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-02-2014, 04:38 AM   #3
Scotman's Avatar
1986 25' Sovereign
Rick,
Thanks for the response and the tip on disconnecting the negative lead. If your trailer has disappeared in a cloud of smoke that's good enough me.
Old 04-08-2014, 09:07 PM   #4
Phoenix , Arizona
It is important to keep the ground as close as possible to your weld. If your ground allows current to go through bearings or other surfaces like them it can ruin them by creating an arc across them. That is why the previous responder gave the good recommendation of removing the negative lead of your batteries. It keeps any chance of it making a complete circuit.
M2HB is offline   Reply With Quote
Old 04-09-2014, 04:27 AM   #5
Scotman's Avatar
1986 25' Sovereign
Following Rick's advice, I finished the welding on Saturday. Electrical systems are fine and the trailer still exists.
Rick, in my previous post I meant to say "If your trailer hasn't disappeared in a cloud of smoke that's good enough me.
Thanks again
cheap heat rv comfort systems - electric conversion of furnace? hshovic Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-17-2012 01:18 PM
frame welding RedBlur Repairing/Replacing Floor &/or Frame 6 05-25-2008 02:31 PM
Electric Systems NewIndianaAS Electrical - Systems, Generators, Batteries & Solar 7 04-17-2008 01:26 PM
TIG welding for a new frame JimGolden Repairing/Replacing Floor &/or Frame 23 01-10-2007 09:29 PM
WD-40....will it harm the finish? Chuck Exterior Restoration Forum 1 07-05-2002 09:50 AM
