Old 09-05-2010, 09:36 AM   #1
1976 31' Sovereign
Indianapolis , Indiana
Wavy staples in subfloor?
We are replacing some sections of subfloor and the old subfloor had these wavy staple type things helping keep the joints of the subfloor together. They are hammered down in there flush with the floor. I don't know what they are called so I'm having a hard time finding them online. The hardware store only had a metal plate with "teeth" in the bottom but it wouldn't be flush. Anyone know what these are called and/or where I can order them from? Thanks!!
Sadie08 is offline   Reply With Quote
Old 09-05-2010, 09:54 AM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
They're called corrugated fasteners or pull-tight staples: Some other non PC names too.
McMaster-Carr
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-05-2010, 10:01 AM   #3
Images: 59
You might have trouble finding the exact length you need.
They don't really add any shear resistance to the floor seams so you can leave them out. They help hold the plywood together during construction, but once you screw the floor to the crossmembers they are no longer necessary.
Here is a previous thread.
Old 09-05-2010, 10:25 AM   #4
Wabbiteer's Avatar
Jupiter , Florida
The fasteners are actually be a long term benefit - since the flex force diagonally from farthest corners are inserting shear forces along the common seam; even minute differentiation between the two with random binding or friction points will eventually soften the crushed clamp area and/or enlarge the bore hole in the wood and/or oblong the threaded lug area in the spar - outriggers...
Those movements are mostly when trailer is in motion but heat/cooling contractions will still be pulling and pushing - for a 40-year design lifetime the corrugated fasteners are cheap insurance.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 09-05-2010, 03:31 PM   #5
1976 31' Sovereign
Found em!
Thanks for the replies! I actually got lucky and spotted them myself at Home Depot a half hour after I posted this Boy they are not the easiest things to hammer in, but we're getting there!
Argosy floor is wavy arcamedies Repairing/Replacing Floor &/or Frame 10 07-29-2010 06:28 AM
Need Advice re: subfloor mwells4654 Repairing/Replacing Floor &/or Frame 7 05-23-2010 08:12 AM
Subfloor damage ck21084 Repairing/Replacing Floor &/or Frame 9 05-05-2010 06:27 AM
Bridging Staples on plywood floor joints - leave or remove? whitelight Floor Finishes 5 04-14-2009 03:06 PM
No subfloor? Over59 Repairing/Replacing Floor &/or Frame 5 05-13-2004 06:41 PM
