Old 08-28-2016, 12:01 PM   #1
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Water intrusion at rear bumper - What years affected?
As a newbie, I've read many threads about - or making reference to - water leaking in from where the rear bumper box meets the shell. Are there particular years affected, or is this a perpetual Airstream 'problem' ... or potential problem?
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 08-28-2016, 12:19 PM   #2
GMFL's Avatar
Dadeville , Alabama
I think our trailer are post bumper problems. I believe Airstream now put a rubber membrane back there to prevent water intrusion. Time will tell at our expense if there plan works!
Old 08-28-2016, 12:59 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
They put in the shell/bumper plate seal beginning with 2012 models. I believe it helped if not totally eliminated the problem in the long run. I still continue to inspect our floor perimeter around our Airstream interior by probing it with a moisture detection meter on a regular basis. Find moisture, fix the leak right away. No moisture, no floor rot.
Doug and Cheryl
Old 08-29-2016, 10:34 AM   #4
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
I read on here they started using sealant in 2015. I know my 2003 had no factory sealant and I just replaced the rear 4 foot of subfloor. Call airstream and ask them
If rear bumper to shell seam is caulked? Way too many rotten floors due to lack of $1.00 worth of Sikaflex 221. Click image for larger version
Name:	ImageUploadedByAirstream Forums1472484777.770841.jpg
ID:	270270Click image for larger version
Name:	ImageUploadedByAirstream Forums1472484791.685538.jpg
ID:	270271. You can clearly see the before and after pics. Nothing to stop the water from just flowing in! Now the water doesn't have a chance!
Kemblkr is offline   Reply With Quote
Old 08-29-2016, 10:49 AM   #5
dkottum's Avatar
Even with the seal, moisture can get to the subfloor from above, down inside the walls, and into the plywood. Awning bracket attachments, window seals, exterior light fixtures, and anything protruding from the roof can eventually leak from use and time.
The moisture detection meter probed into the subfloor on a regular inspection can advise you of a leak before damage can occur, and give you a chance to repair it.
Doug and Cheryl
Old 08-29-2016, 02:22 PM   #6
Watertown , Massachusetts
Moisture meter
Can some of you recommend the best moisture meter to get? There are meters that have a long probe - but they are more expensive. What do you use?
Thanks in advance.
sallye is offline   Reply With Quote
Old 08-29-2016, 02:56 PM   #7
RFP
RFP's Avatar
Hurst , Texas
Yep, I know about how sneaky water can be! Even though I am an Airstream newbie, I'm not new to RVs.
This morning, I went around the perimeter of the 23Ds floor with my Sonin meter... happily, no moisture despite having just been on the road for a month in Colorado, Utah, Arizona, and New Mexico.... with significant raon, too.
All the best
And some stuff
Old 08-29-2016, 04:00 PM   #8
2012 30' International
Livingston , Texas
Several years ago I purchased a Tramex Moisture Encounter Plus non destructive moisture meter . It does not have probes but it does have two rubber pads on the back for contacting the surface. I think I paid about $250 but it is flawless. I'd expect it to be more now. This moisture meter will read through the floor vinyl and let you know if the plywood underneath has moisture. I don't see a model number on it but there is some tiny print stamped into the plastic case on the back. It's made in Ireland.
glenrms is offline   Reply With Quote
Old 08-29-2016, 04:54 PM   #9
RFP
RFP's Avatar
Hurst , Texas
Originally Posted by glenrms View Post
Several years ago I purchased a Tramex Moisture Encounter Plus non destructive moisture meter . <<< snip >>> I think I paid about $250 but it is flawless. I'd expect it to be more now. <<< snip >>>
$347 now... you got a bargain. Wow, this thing is smart!
https://www.amazon.com/Tramex-MEP-Mo...507539&sr=1-16
And some stuff
Old 08-30-2016, 02:59 PM   #10
Kemblkr's Avatar
http://m.harborfreight.com/digital-m...ter-67143.html
$14.99 at Harbor Freight. Works like a champ. Click image for larger version
Name:	ImageUploadedByAirstream Forums1472587164.494211.jpg
Old 08-30-2016, 04:48 PM   #11
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
$8.99 on eBay including shipping! I am ordering one just for fun
http://www.ebay.com/sch/i.html?_from...Meter&_sacat=0
wulfraat is offline   Reply With Quote
Old 04-20-2017, 03:27 AM   #12
1976 29' Ambassador
Dallas , Texas
It's $410 now!!!
tabney0315 is offline   Reply With Quote
Old 04-20-2017, 08:15 AM   #13
2007 28' International CCD
Gulf Breeze , Florida
I just finished sealing the problem joint on my 2007 International CCD. We are the third owner and did not know the unit had rot in the Bedroom until we made a couple of trips. So with the leak fixed I need to tear out all the bedroom...bed, and closets to replace the sub floor. Not excited about this. Shame on Airstream for not taking the time to do it right.
trumpetguy is offline   Reply With Quote
Old 04-20-2017, 05:11 PM   #14
wulfraat's Avatar
Yes, it sucks. Bad. It cost me a small fortune to have all the damage repaired in my 2008 international. The entire interior at the rear of the coach had to be removed including rear shower, and all the plywood subfloor had to then be replaced.
You'll also need to drop the belly pan and replace all of the moisture barrier / insulation that is attached to the underside of the subfloor....
We owned the trailer since new.
We only discovered the damage when we were in the process of laying down new hardwood flooring....
ID:	283779   Click image for larger version
Payload affected by Hitch Weight Tony S Hitches, Couplers & Balls 16 04-14-2011 11:45 AM
Most furnaces in 1960-1977 Airstreams are affected by recalls Jammer Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-10-2011 03:59 PM
pardon the intrusion Y2k_Knight Our Community 2 04-06-2009 10:26 PM
Affected or Effected? RivetED Off Topic Forum 22 02-15-2004 03:15 PM
