Old 11-25-2004, 05:23 AM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Question Water damage to the Rear Bath, '75 Tradewind
In the Off season I have been poking around looking for any areas in need of repair. I found a water leak that has rotted out a portion of the floor behind the shower. Most all of the bath has been removed from this point. See photos here.
http://home.comcast.net/~balrgn/Airs...oject_2004.htm
I am looking for a good flooring to install? Pergo seems to be a good choice?
Has anyone extended the bumper? I am looking to add an extra foot for storage in and on top of while traveling?
balrgn is offline   Reply With Quote
Old 11-25-2004, 07:13 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings balrgn!
I have tried two of the alternatives to carpeting in my coaches - - industrial grade sheet vinyl in the Overlander and Armstrong Laminate with Silent Step underlayment in my Minuet. Both have been quite successful. The biggest down-side to the laminate flooring is weight increase. In the case of my Minuet it added about 100 pounds to the empty weight which means that I am typically less than 100 pounds short of the GVWR for the coach when it is loaded for a long vacation. After living with both of the flooring alternative for more than two seasons, my first choice would be the Congoleum Industrial Grade sheet vinyl as it added less weight and is quite attractive with fewer worries about what might happen if it is exposed to moisture - - the cost difference between the two was negligible.
There are two reason that this project might create more problems than it would solve. First, our Vintage coaches can already be subject to rear separation without adding any additional invitations. My Overlander had a bumper mounted spare tire carrier (added by the original selling dealer) that eventually resulted in separation that required repairs costing close to $2,000. Second, any weight added behind the axles is not a good idea as it can adversely impact towing - - the likelihood of sway problems could increase significantly.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 11-25-2004, 03:37 PM   #3
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Smile Bathroom refinish
That is a good point. I'll keep that in mind and my leave the rear the same length. Need to repair the frame members back there still.
As for the floor, I am leaning trowrds Pergo
Originally Posted by overlander64
Greetings balrgn!
Kevin
Moving the Rear Bath Forward? jabra General Interior Topics 6 07-05-2016 10:52 AM
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 08:52 PM
61 Tradewind Water filter lee_jachter Water Heaters, Filters & Pumps 6 12-13-2003 06:24 AM
Hot Water Heater Exhaust Damage Road Ruler Water Heaters, Filters & Pumps 11 11-11-2002 02:27 PM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 09:00 AM
