Old 04-05-2015, 03:27 PM   #1
1997 30' Excella
Corpus Christi , Texas
Water damage by door
Name:	ImageUploadedByAirstream Forums1428265581.324299.jpg
ID:	235655Click image for larger version
Name:	ImageUploadedByAirstream Forums1428265605.777191.jpg
ID:	235656Click image for larger version
Name:	ImageUploadedByAirstream Forums1428265629.728887.jpg
ID:	235657Click image for larger version
Name:	ImageUploadedByAirstream Forums1428265651.381350.jpg
Knudsvig is offline   Reply With Quote
Old 04-05-2015, 03:28 PM   #2
1997 30' Excella
Door needs adjusting. Not sure if water damage is from sink leak po talked about or from the door
Old 04-05-2015, 03:33 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Is it dry now?
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-05-2015, 03:39 PM   #4
1981 31' Excella II
New Market , Alabama
Check the door gasket. If a dollar bill will easily pull through the gasket then you have a problem. Also check the rivets around the door frame and see if any are loose. Anything leaking on that same section of wall could end up there. There is most likely a gap there where the C-channel meets that door frame. Anything that accumulates in that C-channel will leak out next to the door.
Perry
Old 04-05-2015, 03:51 PM   #5
airdreamers's Avatar
1985 25' Sovereign
Venice/Nokomis , Florida
Images: 14
I had the same damage to my '85 Sovereign. Was able to cut out the bad flooring to just under the cabinet with the heat register, then under the door sill to the side rail holding up the floor edge. As it turned out the leak was from the window frame to the right of the door. Sikaflex fixed it. The flooring beams were still perfect and the screws acually srcewed right out and I was able to reuse them after a little wire wheeling. Good luck with the project. If interested, I may have some pictures of the work, let me know if you want me to find them and post them. BTW, what kind of Airstream do you have?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-05-2015, 05:14 PM   #6
1997 30' Excella
Thank you. Excella 1997 30'
Old 04-05-2015, 05:16 PM   #7
1997 30' Excella
No it's not dry under cabinet and cabinet is wet too
Old 04-05-2015, 05:19 PM   #8
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Is the kitchen sink near the door? Has the plumbing system been pressurized (i.e., used) lately? If it has, it is possible that this water is from a plumbing leak from the kitchen sink area. Get in under there and look around use a mirror and flashlight as necessary.
Bob Martel
WBCCI# 5766
Old 04-05-2015, 05:28 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Good advice. Our sink fittings leaked when our running gear was outing balance
Old 04-29-2015, 09:51 PM   #10
1997 30' Excella
Door eyebrow had the leak. 4 days after sealing it bits still damp
Name:	ImageUploadedByAirstream Forums1430362275.073801.jpg
Running dehumidifier this weekend.
Old 04-29-2015, 10:20 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Getting dry... do you have a dehumidifier/ or put a fan blowing in the area! Also, hit with some Clorine bleach mix...
Channing
WBCCI# 30676
Old 05-01-2015, 01:47 PM   #12
1997 30' Excella
I sprayed with about a 50-50 water bleach solution. Any stains I found I sprayed. Washed and bleached curtains and washed mouse fur. It smells so much better!!
Door Upholstery Water damage xengineer Doors & Locks 1 11-04-2013 02:23 AM
Compartment door to hide damage to skin Kristi Foster Exterior Storage Compartments & Access Doors 1 11-08-2011 05:17 PM
2005 CCD Door and Frame Damage RoadToad Doors & Locks 11 05-10-2005 08:01 AM
door damage dikku@mac.com Doors & Locks 2 04-03-2005 03:25 PM
Door hinge/frame damage Dennis Fahlstrom Doors & Locks 1 07-04-2003 12:50 PM
