Brett,
Thanks for your response.
The gaskets look like they have been replaced. But, they are a light gray, flat looking, about 1/2" wide material. This trailer was a permanent resident in an Airstream only park, about 30 miles from anything. I am finding alot of repairs that used things to just "make do" and are not the proper method. Perhaps this is the case with the window gasket.
I am also curious if the water tank is original or a replacement. The current tank is heavy plastic, an opaque blue color.
Thanks again. This is quite a new adventure, one that I am loving!
I mentioned in my last two posts that my window gaskets appeared to be in good shape. I based this assumption on their clean appearance and supple condition. I also wrote that they are flat, grey, about 3/8" to 7/16" wide. Well, I now think that they should be tubular and have been squeezed permanently flat due to years of compression. We had another downpour this evening so I entered my A/S to watch for leaks. Sure enough, here came the water past the gasket, by the latch shaft, in the wall, out at the floor to the same rotting spots I blamed on the broken water tank outflow nipple. The nipple hadn't caused the rot at all, which makes sense considering this Sovereign has been parked and used as the previous owner's primary residence for at least a decade or so hooked to city water all the while. Which means the tank was probably empty anyway. At least it was when I got it.
So, can anyone verify that my '69 Sovereign's front window gasket shape should be something other than flat?
Thanks overlander 76.
Your reply verifies what I was thinking, that the only adjustment was, how tight the window was squeezed shut by way of the latches. But also thinking it possible I was missing something in spite of the obvious simplicity of the matter.
I do not think the correct window seal was made of gray rubber. It should be black. Your best bet would be to call and get a sample of the correct stuff. that way you can be sure it will fit. I also belive the window seals on your vintage wer a neoprene type of seal, not rubber.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Brett G & Andy,
Thank you for descriptive and informative replies.
Andy, I have the required measurements and am ready to order via telephone. Who should I ask for to speak with in the parts department. I am sure all of your employees are knowledgable, just wondering if there is someone well versed in this particular area. On my Sovereign, each window has two weatherstrips. One in the window opening and a thinner one on the inside of the window frame that holds the glass. Is this how it should be or is one weatherstrip all that is needed (the part number 45295 that you mentioned)? If so, where is the correct place to mount it? What I am trying to ask with questionable effectiveness is this a case of the previous owner trying to improve things? I don't have an original window setup to look at. Does the weatherstrip go on just the frame, or just in the window opening, or both?
One more question... do the compartment doors use the same weatherstrip material? And, what about the water heater compartment door?
I have looked at your website and read much information here, but without an original to look at and only one week's worth of Airstream experience, I have many questions.
I do thank you for your time and patience in answering these newbie questions!!!
Greetings
I called Inland, spoke to Bear, very helpful. Together she and I picked out all the needed items to stop my windows from leaking and causing damage to my floor. Iwill post updates in the window forum. Since I'm replacing all the exterior opening gaskets perhaps my experience will be beneficial to some one else. I hope so.
