Old 02-24-2003, 06:51 PM   #1
Profile:
Water damage
I hear that vintage airstreams are notorious for having water damage to the rear floor as a result of rainwater leaking in around the bumper. Has anyone had any experience dealing with this? I've heard you can seal the area where the water is getting in. Can anyone tell me where that is exactly and how I should go about sealing it? Any help would be appreciated!
Thanks!
65trotter
65trotter is offline   Reply With Quote
Old 02-24-2003, 07:24 PM   #2
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Yep. I'll be rebuilding out 59 this spring. Once it's rotted, especially at the ends you have to replace the wood. The way they are built the wood deck sits on the frame and the rest of the body sits on that. If the deck has rotted then the body droops and strat damaging it.
Go look in the floor repair section. williamhenchel has TONS of pictures posted. I'll be documenting the 59 rebuild as well. Just have to get some other stuff done before I can delve into this fun.
If it's just at the ends you can replace it but just replacing the last few feet but to get the best results in reguards to strength it's best to put full width of the trailer sections.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-24-2003, 07:28 PM   #3
59toaster's Avatar
Atlanta , Georgia
Images: 22
Ohh and it's not really the bumper that causes the problem its leaks anywhere on the body. A water leak around the windows can leak down into the interrior cavities and make it's way to the floor unseen. Really can hav leaks a long distance from where the floor is getting wet.
1959 22' Caravanner
Atlanta, GA
Old 02-25-2003, 06:56 PM   #4
Profile:
Thanks for the info. I will check out the floor repair section for more. Sounds like I've got my work cut out for me!
65trotter
Old 03-03-2003, 08:28 AM   #5
64GT's Avatar
Profile:
I *think* what you are referring to is the condition when you have a storage compartment in the bumper. In that case the water can come down the back of the trailer, settle on the lid and work it's way into the trailer. You need to seal the area where the bumper box lid meets the trailer. Does this make sense? I can send pictures if you need them.
Gillian
64GT is offline   Reply With Quote
Old 03-03-2003, 04:01 PM   #6
Profile:
Water damage repair
I am in the process of repairing the flooring in the rear of our 71 Safari. I have sealed the area above the bumper and would recommend that a bead of caulking be applied in the upper seam area inside the storage compartment. Water can seep through the piano hinge and then up under the flange that it is attached to. If my repairs work, maybe they will last for another 32 years. I'll never know, but maybe our grandchildren will.
Dan
Dbraw is online now   Reply With Quote
Old 03-03-2003, 07:15 PM   #7
Profile:  1967 22' Safari
clarkston , Georgia
Rivet Water damage
Caught the rear wood detirioration on out 67 Safari in time to use marine epoxy to seal it _Git Rot I think on some soft areas but they were not rotten away too badly at all.Did the Vulkem sealer on the girdle/bumper areas and will get the piano hinge (if I haven't already) Also did some git rot around the throne/floor connection for posteriority. tod47d
tod47d is offline   Reply With Quote
Pingbacks are On
Water Damage jjonesnc Repairing/Replacing Floor &/or Frame 21 07-10-2003 05:20 PM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 11:50 AM
Frame Damage (Rust under water Tank klanke Repairing/Replacing Floor &/or Frame 3 04-06-2003 08:34 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
Hot Water Heater Exhaust Damage Road Ruler Water Heaters, Filters & Pumps 11 11-11-2002 02:27 PM
SEO by vBSEO 3.1.0
