Old 06-19-2004, 07:58 AM   #1
Question Water Damage
I have a 1988 Excella 32ft. I have pulled the carpet and have dicovered that the flooring at all 4 corners( curves) has rot due to water leaks. I can repair the floor but what is the best way to determine where the problem is?
Philip Williams is offline   Reply With Quote
Old 06-19-2004, 10:57 AM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I think the best way to help you is to have you do a search for "floor repair" and "water leaks" and see what you think. Basically there are two methods for floor repair, penetrating epoxy, or cut the bad section out and replace with new wood.
Leaks can be tough, basically start with a garden hose on the bottom of the trailer and work your way up until you see water coming in.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 06-19-2004, 10:58 AM   #3
Ken J's Avatar
Durango , Colorado
Images: 14
BTW - a big welcome to the forum!
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 06-22-2004, 08:16 AM   #4
Ken
Since I am new to this I was not aware that water damage was a relatively common thing. I now am and will get the hose out! Thanks.
Old 06-22-2004, 08:20 AM   #5
FireFighter's Avatar
bay city , Michigan
positive pressure
also i read somewhere on the forumn to soap all of the seams around the area in question then use (if you have fantastic fans to pull air into the trailer) or use a large box fan in one of the windows, the goal is to add a little pressure to the TT which should make the soap bubble at the leak
FireFighter is offline   Reply With Quote
Old 06-22-2004, 08:51 AM   #6
Ken J's Avatar
Durango , Colorado
Images: 14
One other thing, if you use epoxy, make sure the wood is BONE dry........
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
fire damage in water heater area mtpalms Interior Restoration Forum 2 04-06-2004 05:43 PM
Water Damage jjonesnc Repairing/Replacing Floor &/or Frame 21 07-10-2003 05:20 PM
Frame Damage (Rust under water Tank klanke Repairing/Replacing Floor &/or Frame 3 04-06-2003 08:34 AM
Water damage 65trotter Repairing/Replacing Floor &/or Frame 6 03-03-2003 07:15 PM
Hot Water Heater Exhaust Damage Road Ruler Water Heaters, Filters & Pumps 11 11-11-2002 02:27 PM
