Old 12-09-2012, 09:43 AM   #1
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Warning sign?
Have a friend looking at a 2002 classic 34'. Nice trailer but on the curb side, immediately behind the last tire where the wheel wheel returns to the wrap, there is a outward pucker in the body panel (about 3" X 5"). On the street side in the same location, there is one missing rivet but no pucker.There is no visible damage to the interior wheel well or other indication of why the panel might have been pushed rearward. There are no other signs of a problem. No pictures available and we can't go back and look at it again. I know it's difficult to diagnose from afar, but is there any chance this is an early indicator of a frame problem? I found no evidence of soft flooring in the areas I could access.
Greg
Roadtoaster is offline   Reply With Quote
Old 12-09-2012, 10:09 AM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
The 34'ers have a very long overhang, which causes a lot of stress on the frame just behind the axle mounting plate, & this is where the "pucker" is. I have seen this quite a bit, & yes this is a symptom of frame issues. The end of the outriggers tend to sag in this area relative to the frame rail & the frame rail itself sags gently. These trailers really need a "sister rail" between the axle mounting plate & the "L" attached to the bottom of the frame a couple feet aft of that. If you place two hydraulic jacks at the rear of the frame rails, & lift until you see the "pucker" disappear, this is when you would install the "sister rails", thus removing the weak point in the frame. Keep in mind that this doesn't happen on all of the 34's, but I suspect it is dependent on how & where the trailer was used.
Good luck,
Colin
Colin H is offline   Reply With Quote
Old 12-09-2012, 10:18 AM   #3
Colin, coming from you I will take this to heart. Many thanks for the quick reply.
Greg
Old 12-09-2012, 10:22 AM   #4
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
no problemo
