Old 09-08-2004, 03:49 PM   #1
Profile:
vinyl tile vs. one piece vinyl
if I wanted to replace the floor with a vinyl flooring would it be better to use a one piece unit compared to the tiles. it seems like the tiles would run the risk of getting water under them just from general use, but they may look nicer. as with the one piece you could just lay it down then run a bead of silicon around the parimiter. also has anyone ever had their flooring tear on them. from like sliding a chair across it. it would seem that the tile would be easier to fix in this sort of instance. thanks for all of your guys feed back so far on all my threads. theres nothing like haveing years of experience and a bunch of trail and error that i wont have to go through because of you folks. thanks.
loki is offline   Reply With Quote
Old 09-08-2004, 03:57 PM   #2
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I put in armstrong stick on tiles a couple of years ago and I don't like them. Some are lifting up, gaps between others. Dirt gets in between when sweeping...
Keep in mind I probably installed it wrong ;-)
I am now researching putting in the sheet vinyl myself. Looks like it will have to have at least one seam in it because it looks like it comes in 12ft widths and I don't want to have a lot of waste. So then the problem of makeing a seam joint work....
Still researching. Looking forward to this thread.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 09-08-2004, 04:16 PM   #3
Craftsman
Guest
Profile:
Posts: n/a
Go with one piece. Individual tiles are subject to movement and getting dirt in the seams.
When that happens the floor always looks dirty.
Old 09-08-2004, 04:26 PM   #4
Profile:
see that is exactly what i was wondering. the tiles seem like it could be a real pain after a few years. it just seemed easier and cheaper. keep me informed on your research and i will do the same for you. the seam seems like it could also be risky if it were done wrong. thanks.
Old 09-08-2004, 04:27 PM   #5
Profile:
good to know. I have two dogs and they bring in alot of dirt. they are one of the reasons i worry about it tearing also.
Old 09-08-2004, 04:45 PM   #6
Nick Danger's Avatar
Profile:  Beverly Hills , Florida
Smile
I installed the Armstrong Epiq Plus 12" vinyl tiles. They look great and I have had no problems. I think the key to a successful installation is prepping the surface the tiles will bond to. Under no circumstances should you ever attempt to install vinyl floor tiles over OSB ( oriented strand board aka particle board). You're begging to re-do it properly. If your coach has an existing OSB underlayment as mine did, install an underlayment of 5/32 luan plywood over the OSB. Be sure to use galvanized screws ( 1 inchers are fine). Prime the luan with a latex primer. Armstrong's primer product is called S185 and is available at Home Depot and Lowes.
Take your time when installing and butt the joints as tight as possible. Dry fit each piece (whole and cut pieces) with the paper still on before applying to the luan. Don't forget to lay it out before you start laying tile so you don't end up with short crappy looking pieces on the edges or around the steps. My joints are almost indistinguishable and the tile holds tighter than Dick's hat band.
Hope this helps.........
Nick Danger, Third Eye
Nick Danger is offline   Reply With Quote
Old 09-08-2004, 04:49 PM   #7
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Then I have a deal for you
...So then the problem of makeing a seam joint work....
Well, in that case, allow me to brag/lament that I wanted no seams, and bought enough of the 12 foot roll to accomplish my madness.
If seams do not bother you, I have 20+ feet of high quality vinyl on a four foot roll left over that I will send you for the cost of shipping.
Check my photos and see if you're interested.
I'm funny about things like seams, but I'm serious about giving the rest away; It goes against my grain to throw things like that away. But I will after I get tired of moving it out of the way
Tom
Old 09-08-2004, 05:05 PM   #8
Safari Tim's Avatar
Images: 35
Thanks for the offer Tom.
But I'm with you. Don't really want seams. But I maybe able to live with one depending on the cost savings.
Looks like you did a really nice job on your floor install. Looks great!
-Tim
Old 09-08-2004, 05:44 PM   #9
TomW's Avatar
Originally Posted by Nick Danger
...Under no circumstances should you ever attempt to install vinyl floor tiles over OSB ( oriented strand board aka particle board)...
Mr. Danger (aka third eye),
OSB is not the same as particle board. OSB is big pieces of wood, particle board is sawdust. Vinyl floor works fine over OSB (look at new Airstreams). Particle board is an extremely poor choice for an Airstream no matter what the floor covering is.
Tom
Old 09-08-2004, 07:56 PM   #10
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
No adhesive, no matter?
My '04 has a one-piece/seemless vinyl 'faux-wood' floor from the factory, but it is NOT fixed to the sub-floor with anything other than gravity, friction, & the interior components of the trailer holding it in place. I'm no expert on this, but I don't think it matters what type plywood, or any type of wood, is under a benign vinyl floor covering provided it is acceptably smooth to the user??..
RivetED is offline   Reply With Quote
Old 09-08-2004, 09:16 PM   #11
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
We just went through that same dilemma after having a leak from our toilet pedal valve that put the final ax on the loathed bathroom carpet. Anticipating problems with multi tiles, edges, gaps, and so on, we selected a base line, inexpensive sheet vinyl, added a slight subfloor to even up all surfaces, and then put down quarterrouond to polish the effect. What did look awful, now looks clean, fresh, and easy care. Hardest parts? Getting the carpet removed up to the edge of walls, doorways, and then getting the vinyl to fit well under the sliding doorway between bath and bedroom. It's done, and looks great!
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 09-08-2004, 10:02 PM   #12
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
I too, have been exceptionally well satisfied with the sheet vinyl installation in my '64 Overlander. Three years ago, I had Fowler Interiors of Symsonia, Kentucky refurbish the interior of my Overlander and this included the floor covering. Upon the advice of Arlene, I chose a very heavy-duty industrial grade Congoleum sheet vinyl and to keep costs down a single seam was used. The subfloor was carefully prepared with a thin luan underlayment covering the original plywood subfloor - - the seams as well as any imperfections in the luan were filled with materials recommended by the flooring manufacturer. To this day, that seam is nearly invisible, and the installation looks as good today as it did three years ago - - it also has proven to be totally Chihuahua-proof.
Kevin
Kevin D. Allen
AIR #827
Old 09-08-2004, 10:09 PM   #13
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Nick -- You wouldn't happen to know a Betty Jo Bieloski? It's good to run into somebody else in their mid-50's. No-o-o-o, it's GREAT!!!
Old 09-09-2004, 12:51 AM   #14
Safari Tim's Avatar
Images: 35
What's the difference between sheet vinyl and linoleum?
-Tim
Vinyl Tile Too Heavy? fireflyinva Repairing/Replacing Floor &/or Frame 14 08-15-2006 10:25 PM
Single sheet vinyl solution? TomW Floor Finishes 19 03-26-2004 08:53 PM
Tile or single piece vinyl? Andy R Floor Finishes 36 05-10-2003 07:56 PM
Bathroom tile ALANSD Floor Finishes 2 03-07-2003 12:12 AM
Grades of vinyl... Andy R Floor Finishes 2 05-31-2002 12:47 PM
