Old 10-28-2004, 05:35 PM   #1
mbatm01's Avatar
Profile:  1963 22' Safari
Broomfield , Colorado
Underlayment on top of new floor?
As you may have read in other posts, I am almost done with the shell off floor replacement. I am not sure what type of floor covering we will choose yet, but regardless of covering type, should I install Lewan underlayment over the new floor?
Part of me thinks it would be nice to have a seperate layer for glue etc... rather than glueing directly to the new floor. The other part of me wonders if its too much weight and that I don't even need to worry about it.
Any thoughts?
Kevin
mbatm01 is offline   Reply With Quote
Old 10-28-2004, 06:08 PM   #2
Profile:  , Minnesota
Images: 59
Airstream Registry
I think it sounds like a good idea. I've been pondering the same thing. If you use 1/8" Luan I don't think the weight would be too much, and the weight is low down and spread out.
Old 10-28-2004, 06:40 PM   #3
Over59's Avatar
Profile:  1959 26' Overlander
Putnam , Connecticut
Images: 37
If you are putting down one of the snap together panel floors (pergo) then I don't see what advantage the extra layer and money gets you. If you are doing sheet flooring and your floor is not suitable for the adhesive or is rough then it may be a good idea.
I think you need to commit to a floor before you know what to do or you may make extra work for yourself.
TAC & SOFI Member Rock On
Over59 is offline   Reply With Quote
Old 10-29-2004, 09:12 PM   #4
mbatm01's Avatar
Great points to consider, I appreciate your responses. Right now we are leaning towards carpet tiles, so glueing those to Luan would be nicer to remove in the future should we ever decide to change.
Kevin
Old 10-30-2004, 03:17 AM   #5
fireflyinva's Avatar
Profile:  1961 22' Safari
Vienna , Virginia
Interesting thoughts...BTW--As I get ready to refloor, I also wonder if anyone has installed a vapor barrier in between the flooring and the underlayment? What advantages/disadvantages?
Mray
fireflyinva is offline   Reply With Quote
Old 10-30-2004, 03:21 AM   #6
Vienna , Virginia
Just as I finished posting the last message I happened to notice that one of the sponsors on this forum (http://mantoncork.com/) advertises cork underlayment. That might be better than luan (softer, but I 'm not sure about durability)...
FWIW,
Mary
Final Floor Replacement Technique JohnG Repairing/Replacing Floor &/or Frame 46 01-15-2006 03:43 PM
Body and banana wrap on floor replacement technique. malconium Repairing/Replacing Floor &/or Frame 56 09-09-2005 09:09 PM
Floor is not flat mbatm01 Repairing/Replacing Floor &/or Frame 3 09-15-2004 03:57 PM
Plywood underlayment information Pam Repairing/Replacing Floor &/or Frame 1 07-22-2004 02:51 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
