Old 06-15-2016, 08:23 AM   #1
1962 24' Tradewind
Springfield , State
Under floor insulation??
Hi all, I'm doing a frame off restoration on my 62 trade wind. I'm almost to putting new belly skin on and was wondering what others would recommend for insulation. I was thinking about 4 x 8 sheets of the pink closed cell foam, cutting it to fit and screwing it on in between the frame sections.
Any other ideas and can anyone confirm that insulating is worth the time effort and cash?
Thanks in advance!
Scott P
Scott P. is offline   Reply With Quote
Old 06-15-2016, 09:22 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I did essentially what you are thinking of doing: a couple layers of closed cell foam with a final layer of she shiny bubble wrap looking down. Held in place with spray adhesive and screws with big plastic washers. Thickness of my assembly is about 1.5". I figured that it didn't make sense to obsess about the insulation in the walls and then leave the floor completely uninsulated. Can't really tell if it makes a difference or not, since I don't have anything to compare to. Just beware that if you have or will have tanks under your floor and inside your frame, that yo won't be able to insulate very thick, or maybe at all where the tanks go.
good luck!
Old 06-15-2016, 09:24 AM   #3
1962 24' Tradewind
Springfield , State
Thanks for the info!
Old 06-19-2016, 10:08 PM   #4
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
I decided not to insulate my floor. I typically do not use my trailer in extreme heat or cold. Just an occasional weekend. If I was full timing I would have insulated.
AlbertaBound is offline   Reply With Quote
Old 10-31-2016, 10:06 AM   #5
1960 24' Tradewind
Tipp City , Ohio
Has anyone had any luck using mineral wool insulation under floor? Roxul?
streaming24 is offline   Reply With Quote
Old 10-31-2016, 10:23 AM   #6
1974 25' Tradewind
Calgary , Alberta
I think that will be our choice. But I won't use Airstream's method of retaining the batts (which is, to lay it down across the frame members and then crush it down with the wood floor. I think the notion of spray adhesive would work for when the material is first installed but then you have to expect the fibers to slowly separate over time. I will probably cut strips of Coroplast about 1.5 to 2 inches wide to act as bottom side straps, and use 3 inch screws to attach them to the floor from below. That way the insulation should stay out of the way of whatever moisture ends up on the bottom sheet metal. I know the Roxul is hydrophobic but the more you keep it away from moisture the better it will be.
Alumineer is offline   Reply With Quote
Old 10-31-2016, 11:20 AM   #7
Images: 59
I also thought the original method was less than satisfactory. I used 3" fiberglass batts, held off the bellyskin with steel strips.
I don't think Coroplast was available, or I wasn't aware of it at the time. I might go that route if doing it today.
ID:	274590   Click image for larger version
Old 10-31-2016, 07:05 PM   #8
1992 29' Excella
seattle , Washington
concerned about water sloshing about
I too am trying to figure out what type of insulation to use instead of the pink stuff for my sub floor. I am replacing only the front and rear sections of sub floor, but in so doing, I've definitely noticed areas under the good parts of the sub floor with sloshy insulation. (times like these I wish I had x-ray vision)
Plan after finding and repairing all leaks.
1. get all sloshy insulation all dried out otherwise it will just rot the remaining floor sections
2. cover the holes in frame with a rubber plug or spray foam insulation to prevent water from coming in from below. But I also think this is a way for water to get OUT so I need advice. IF I cover holes in frame, I was thinking of putting some vents UPWARD into the floor to allow any water that got trapped down there a chance to evaporate.
3. use either rigid foam OR that space suit (silvery) insulation
stephseattle is offline   Reply With Quote
Old 11-01-2016, 07:57 AM   #9
Belegedhel's Avatar
Houston , Texas
Don't seal up your belly pan or things will never dry out. That being said, you don't want gaps and holes that are big enough to allow rodents in, those should be patched, but not sealed.
Old 11-02-2016, 07:43 AM   #10
1960 24' Tradewind
Tipp City , Ohio
Under floor indulation
What about between new grey tank and plywood floor? Insulation? Vapor barrier? Nothing?
Old 11-02-2016, 08:32 AM   #11
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Rigid foam is lite and insulates good with no water retention. Click image for larger version
Name:	ImageUploadedByAirstream Forums1478097151.521785.jpg
Batts of anything may collect moisture.
Matt
rugjenkins is offline   Reply With Quote
Old 12-19-2016, 04:25 PM   #12
1966 30' Sovereign
Boulder , Colorado
What thickness/R Value did you go for with this material? I am finishing (tomorrow?!!) replacing my entire subfloor and the Mrs wants toasty toes. I see that rigid foam from HD comes in a full range 2 to 7 and $11-20. Is there a diminishing return at some point?
Garrett7m is offline   Reply With Quote
Old 12-22-2016, 08:00 AM   #13
1977 31' Excella 500
Dallas , Texas
On fiberglass batts. please read installation instructions. I believe the paper is a moisture barrier and faces the conditioned airspace. Also, I believe fiberglass insulation should dry out if water is not ponding and wicking up constantly.
Jack Moore is offline   Reply With Quote
Old 12-22-2016, 08:47 AM   #14
r carl's Avatar
Lin , Ne
Rock wool in the walls and ceiling for sure. Fiberglass batting should not be considered for a camper. Blue or pink board can be fitted under the floor.
Insulation under the floor vanster Repairing/Replacing Floor &/or Frame 7 03-06-2015 07:57 AM
Under floor insulation? colin57 Repairing/Replacing Floor &/or Frame 10 05-02-2011 02:15 PM
What insulation did you use under the floor? adwriter73 Repairing/Replacing Floor &/or Frame 32 03-04-2010 08:01 AM
Should there be insulation under the floor? rlindberg Interior Restoration Forum 9 05-18-2009 11:10 AM
Under floor insulation Rick Alston Repairing/Replacing Floor &/or Frame 18 01-26-2004 08:02 PM
