Old 12-27-2007, 07:50 PM   #15
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
What material?
Cosmos
Exactly what material are you using for your new floor?
Old 12-27-2007, 08:25 PM   #16
cosmos's Avatar
1965 17' Caravel
Birmingham , Alabama
Images: 8
I'm using 5/8" B-C ULX exterior plywood. It looks weird because I primed and painted it on both sides and on all edges. Way overkill for most folks. My wife has a sensitivity to formaldehyde and some plastics so I'm primarily blocking the offgassing from the glue in the new plywood. I hope to get more water resistance in the deal as a bonus. Thats a roll of formaldehyde -free insulation in the back of the picture.
cosmos is offline   Reply With Quote
Old 01-14-2008, 04:25 PM   #17
cosmos's Avatar
1965 17' Caravel
Images: 8
Caravel mystrey leak solved
I'm in the process of replacing the front sections of floor in the Caravel now. I took the forward inside wall out and removed the old insulation. I was shocked to find that my mystery leak was coming from the Caravel nameplate! And I thought it was the door gasket. The cast script nameplate has four cast pins that go thru the outer skin to hold the emblem on. I could actually see light out the holes around the pins. The inside of the wall had water stains running in through these holes. Judging from the water stains on the wall, it was a significant leak. As I think about it more, the awning rail and the door gutter direct lots of run-off water at the nameplate.
The emblem was held on with spring- type push fasteners typical of the cars of the era. I slipped a piece of wire under the springs and carefilly lifted them to pull the clips off. Then after cleaning up the emblem and its mounting point, I pushed it back in place and sealed the holes and studs from the inside with Vulkem. This way if I have to remove the emblem again it won't as hard to clear off the Vulkem. I also put a thin piece of plastic on the stud so the push fastener won't be imbedded in the Vulkem.
Old 01-15-2008, 09:18 PM   #18
1968 26' Overlander
Stevensville/Fort Fun , Montana
Great Fixes by P.O
Speaking of great fixes by PO. I had to pry up three different sheets of plywood in order to get to this. He must of got to lazy to fix the floor rot, and just laid plywood over it, thinking it would go away. Out of Site, Out of Mind; He must of thought.
out4trout is offline   Reply With Quote
What CB channel do Airstreamers use? Airstream25 Phone, CB & Ham Radio 52 09-28-2011 06:58 PM
Where to buy U-C Channel hazelcreek Repairing/Replacing Floor &/or Frame 9 03-10-2007 06:30 AM
channel question robbp Repairing/Replacing Floor &/or Frame 1 08-29-2006 11:39 PM
Outrigger wear to tire contact Johndigbydog Tires 10 01-20-2006 10:03 PM
History Channel markdoane Off Topic Forum 0 06-25-2005 12:23 PM
