Old 04-21-2011, 10:15 AM   #1
crzycpa's Avatar
1949 18' Trailwind
Upland s/n 5060 , California
Images: 41
Tube Frame Debate
I have a 1949 Airstream Trailwind with a tube frame (the frame is actually in very good shape). The trailer is currently going through a total renovation which includes a new axel. I've read many accounts where the tube frame has been replaced or at least shored up during renovation. I'd appreciate your opinions from both those who have replaced/shored up the frame and those who haven't to better assess the path forward.
Thank you for your input,
Tom
crzycpa is offline   Reply With Quote
Old 04-21-2011, 12:23 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I like pipe
If the pipe is structurally sound I see no problem with using that original set up. Rust out is another subject....as it is with a ladder frame.
There are enough formed aluminum cross members to support any reasonable installations topside. The floor is a major contributor to strength. I would go with a 3/4 instead of the original 1/2 plywood. You will run into some other interesting problems like propane bottle mounts, sway control , turning radius
and jack....all part of the process.
On your little baby....I'd stay with the pipe unless expense is not a problem.
Name:	Pipe frame floor removed.jpg
Old 04-21-2011, 12:45 PM   #3
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
If the pipe is to remian, and I would keep it,
1. fabricate better pipe to rib connections. Yours has simple tabs. In my 1950, it had a bracket that circled the pipe and provided much better connection.
2. Create a connection between side steel channels that the running gear is attached to and to a V towards the hitch. In David Winick's boot he illustrates his redo of a trailwind and has this mod made.
3. the pipe will limit the size of any one holding tank if you choose to place any below the floor.
4. if you integrate a steel frame it will give you places to hang tanks, mount stabilizing jacks, etc. The Aluminum ribs are not good choices for this as they are just .032 sheet.
5. If you go with thicker plywood, you will add about 30lbs per sheet of plywoord per extra 1/4 inch. It may not seem like much, but remeber that each little bit adds up with all your upgrades and mods.
Gene
FC7039 is offline   Reply With Quote
Old 04-21-2011, 01:17 PM   #4
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yes...
pipe attach picture for those not familiar
Name:	pipe frame detail.jpg
Old 04-21-2011, 01:56 PM   #5
crzycpa's Avatar
1949 18' Trailwind
Images: 41
Thank you Melody Ranch and FC7039 for your input.
A picture of the frame is located at 1949 Trailwind View Of Frame - Photo Gallery or you can see it at 1950s Airstream Trailers or my member gallery.
Old 04-21-2011, 02:28 PM   #6
FC7039's Avatar
Allen , Texas
THIS is what I did. Also, you can look at David Winik's book as he redid the same trailer.
Old 04-21-2011, 05:07 PM   #7
1972 Travelux Princess 25
Cobourg , Ontario
If the opinion of someone who does not own one means anything....
It seems the original frame was plenty strong for the original trailer.
When you rebuild one and add all the modern conveniences, more propane tanks, bathroom, water tank, holding tank etc. you pile on a lot more weight than the original design was meant to handle.
At this point you need a stronger frame, stronger axle, better brakes, etc etc etc
In other words, you have to build a whole new trailer and cover it with the original skin. You no longer have the light weight aircraft inspired trailer you started with.
To me it would make better sense to stick to the original design intent. If you want a more lavishly equipped trailer buy a newer one that is designed that way from the start.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 04-21-2011, 08:07 PM   #8
crzycpa's Avatar
1949 18' Trailwind
Images: 41
Thank you for your input and your point is well taken. We are planning to stay pretty true to the basic design maintining the original woodwork and sink/counter. We will replace the existing mattress with a foam bed but that may actually save weight. There will be some weight gain from adding a small refrigerator, a horseshoe couch at the front and a low profile heater/airconditioner. If we add tanks they will be on the small side so overall the increased weight should not be excessive. I like your thought that less is more. I'd be happy if you would check back in June (targetted completion date) and see where we end up.
Old 07-05-2011, 09:29 PM   #9
1966 22' Safari
Seven Valleys , Pennsylvania
How we did ours
http://www.airforums.com/forums/f36/...ork-43371.html
Gene's is probably a wayyyy more solid foundation, but also wayyyy more work.
scarylarry is offline   Reply With Quote
Old 07-05-2011, 09:34 PM   #10
1966 22' Safari
Also a little video Tom from the WDCU did when I crashed their rally earlier this year!
tube frame 1950
frame reinforcement - rear end separation silversafari Repairing/Replacing Floor &/or Frame 1 03-17-2011 10:16 AM
how do I diagnose frame damage on '59 18-footer cindy Repairing/Replacing Floor &/or Frame 0 03-11-2011 01:43 PM
1965 Caravel Frame funhouse 1965 Caravel 0 03-01-2011 09:12 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
Ready To Begin Tear Down To Frame.?.?! Althea68 Repairing/Replacing Floor &/or Frame 11 01-26-2011 04:28 PM
