1972 29' Ambassador
Currently Camping
, Pennsylvania
Trim/Moulding Around Floating Floor?
How can and where do you attach trim around the edges of a floating floor? Or, how do you finish the edges if you don't use it?
I put cork down with a 1/8" margin around the edges, but don't know what sort of trim options I have since I can't nail or screw into the aluminum walls.
The only place I use silicone adhesive on the Airstream. Under the cove or 1/4 round. It seals to the floor, keeps spilled liquids away from the walls and it allows for easy maintenance. Besides, if you fill the expansion space at the edges it allows for that expansion .
__________________ "If it can't be reduced, reused, repaired, rebuilt, refurbished, refinished, resold, recycled or composted then it should be restricted, redesigned or removed from production."
