Old 09-19-2016, 07:27 AM   #1
coolbabe's Avatar
1976 Argosy 26
Lake wales , Florida
Trim for Wood Plank Flooring
I have installed wood plank flooring in my 1976 Argosy. I am unsure what to use and how to instill the trim. What did you use? Or any ideas? Because of the shape I would think a trim that is bigger on the bottom than the top would have to be used. Has anyone used aluminum?
coolbabe is offline   Reply With Quote
Old 09-19-2016, 07:58 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Cove moulding (aluminum) you can get it or order it thru any hardware store. Quarter round at the same store for wood or synthetic....they have refinished and its worth it to use it. I fasten it with Vulcum....planning for future work.
Old 09-19-2016, 08:02 AM   #3
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Lots of options. With the right tools you can easily attach wood moulding. Pictures of your project-in-process would most likely garner some good suggestions.
youngpeck is offline   Reply With Quote
Old 09-19-2016, 01:26 PM   #4
coolbabe's Avatar
1976 Argosy 26
What is Vulcum?
Old 09-20-2016, 11:57 AM   #5
1996 25' Excella
Tillsonburg , Ontario
I would think Vulcum is a bit too permanent. Once cured it has to be scraped off. If I were doing it and wanted to use a caulking as glue I would use Mono or any acrylic (not silicone...same problem) The acrylic or modified acrylic polymers used for calking windows and siding can be cleaned off with Varsol down the road. You will still need to shoot a few nails to hold the trim in place, so why not just nail the trim and make it easier and simple.
JCW
JCWDCW is offline   Reply With Quote
Anyone tried COREtec plus vinyl plank flooring? dirtman Repairing/Replacing Floor &/or Frame 13 12-07-2017 08:09 PM
Allure Traffic Master Vinyl Plank Flooring Chillbilly Floor Finishes 56 05-25-2017 07:33 PM
New carpeting and vinyl plank flooring JMSx2 Land Yacht/Legacy Motorhomes 12 05-20-2014 05:09 AM
Picture of vinyl plank flooring installed spaceghost65 Repairing/Replacing Floor &/or Frame 6 08-19-2013 11:37 AM
Wood Plank vinyl flooring wvabeer Land Yacht/Legacy Motorhomes 33 07-08-2013 05:13 PM
