Old 09-01-2004, 04:51 PM   #15
Images: 59
Ken,
I tried that, but the rivet line is above head level, and the rivet bucker (son-in-law) was standing inside on the ceiling. I didn't mind working on a ladder, but the footprints are a big problem.
Old 09-01-2004, 08:17 PM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Steel wool? I picked up some brass wool at HD a couple weeks back. Steel wool has so much surface area it seems to rust extremely easy.
My '76 has the box ends up by the hitch ball just like Don's. I had a lot of internal rust, whether from the seashore or parking long-term in overgrown grass. The hole for the breakaway wires was quite rude. I used the Por-15 Epoxy Putty. Wear gloves!! (cheap in paint finishing departments or the livestock supply areas of our fleet stores) It was easy to work and I tried to get about 3/4" contact with the beam insides. Hardened in a couple hours and was superhard overnight. I did not seal the back end up under the belly wrap -- figured I didn't want to let moisture in the odd rivet hole and never let it back out.
5 meter Langford Nahanni
Got to ask.. Have I got Frame seperation? JohnG Repairing/Replacing Floor &/or Frame 7 07-23-2004 11:21 AM
Rust Question drober05 Airstream Motorhome Forums 6 10-05-2003 02:09 PM
Frame rust out eracism Repairing/Replacing Floor &/or Frame 2 08-07-2003 06:15 AM
Frame rust Ken J Repairing/Replacing Floor &/or Frame 5 07-13-2003 06:39 AM
Frame Damage (Rust under water Tank klanke Repairing/Replacing Floor &/or Frame 3 04-06-2003 08:34 AM
