Old 04-17-2007, 03:39 PM   #1
Devils Lake , North Dakota
Question Treat Floor???????
I pulled up the PO's (wow I'm even using airstream lingo!)
vinyl flooring in preperation for a wood laminate.
The floor is rock solid with zero soft spots nor indications of
prolonged wet areas.
I did notice that the wood was on the damp side under the
vinyl....... I'm guessing condensation??? It is airing out with
a good breeze.
Has anyone treated the wood prior to flooring??? Like a
Thompson's or simular product??
Should I put down a vapor barrier before the laminate?
Sundance is offline   Reply With Quote
Old 04-17-2007, 03:54 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
a good breeze.
Thompson's or similar product??
No vapor barrier, traps moisture.
Look along your lower trim, may have moisture seeping in. I have not treated the floor in any of the ones I have done. (6 or so)
Check out my website if you are looking for pics.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-17-2007, 04:01 PM   #3
highmark's Avatar
1977 24' Argosy 24
Swan Lake , Montana
Sundance - The floor on my 1977 Argosy 24' was similiar to yours. After I pulled up the existing flooring I went online to Wood preservation, rot repair, and restoration using epoxy resin on boats and homes. and ordered the CPES that has been discussed a great deal on this forum. It was easy to apply and to me was a preventative action. I did have one weak spot, but the CPES tightened it right up. One gallon of each component did my floor with two coats and some leftover. Check out their website - they were great people to order from and have a great product!!! I do belive that laminate floors require some type of barrier (I think it is some type of paper), but best to check with the person you purchase the flooring from. Good luck on your project! Highmark
highmark is offline   Reply With Quote
Old 04-17-2007, 04:03 PM   #4
Assume I find a damp spot adjacent to the lower trim issue...
What is the fix???
Your projects look fantastic balrgn. I'm envious. I sure wish
the Argosy did not have the front water tank. I love that
love seat look.
Old 04-17-2007, 04:07 PM   #5
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
What is the fix???
love seat look.
It is a fairly easy fix, remove the trim, and seal it. Check this link on how to.
Leak Repair
This is a common water intrusion point.
www.balrgn.com
Old 04-17-2007, 04:32 PM   #6
Thanks a ton..... great pointer and pics
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 12:21 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 04:08 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 07:28 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 12:11 PM
Total floor replace 74Argosy24MH Repairing/Replacing Floor &/or Frame 1 06-27-2002 05:05 PM
