Old 06-26-2002, 10:57 AM   #1
74Argosy24MH
Profile:  LOST , Hawaii
Total floor replace
William Henshall's saga replacing his floor raised a question for me. I replaced the floor in my 74 motor home; in this the plywood slides in a track that looks like an addition to the bottom of the channel used on the trailers (from his pictures it appears to be a u-channel which sits on top of the plywood).
When I pulled the body, I pulled the floor with it, because it was in the track. The instructions I have seen say remove the rivets and leave the channel. This is my question, why not pull the channel with the body? It would seem like it would leave a lot of support, and be much easier to set the flat channel back on the floor deck than try and fit the body over the channel.
74Argosy24MH is offline   Reply With Quote
Old 06-27-2002, 04:05 PM   #2
williamhenshall
Profile:
Images: 171
Good point but...!
On my 58 Traveler, I actually tried to leave the u-channel on the shell and take them both off together, leaving the floor clean.
The problem is that the belly pan is riveted through this to the top shell and you have to drill out all the belly rivets to get the belly off...and the belly rivets are *underneath* the shell rivets, so, ahem, you can't get there from here!
WBCC #8048
1958 18Ft Traveller
Los Angeles CA
williamhenshall is offline   Reply With Quote
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
total overhaul need advice nevisstudio Interior Restoration Forum 40 04-24-2004 01:51 AM
For Sale 1976 25' Caravanner bigshinything For Sale & Wanted 32 01-22-2004 08:59 PM
(total newbie question)Compressor/Airbags in a 76 argosy 24? 76Argosy24_Thomas Mechanics Corner - Engines, Transmission & More... 4 11-12-2003 01:08 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 1 09-04-2003 01:10 PM
