Old 06-10-2019, 04:30 PM   #253
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Make sure the string still has a good coat of wax or grease on it . After packing the nut as it is tightened squeezes down and makes the seal . Make sure the shaft is smooth . Good luck .
Joyflea is offline   Reply With Quote
Old 06-11-2019, 07:39 AM   #254
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I'll give it a go tonight, thank you Joyflea!
Dingo Girl is offline   Reply With Quote
Old 06-11-2019, 10:39 AM   #255
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You can buy a teflon "string" at Lowe's and Home Depot, that is specifically designed for this application. I've used it to repair outdoor faucets, and it was quite effective and painless.
good luck!
Old 06-11-2019, 07:25 PM   #256
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Gee, I've never used a packing string. My old faucets have what looks like a cork sleeve that fits around the stem. Then I tighten the packing nut so I don't get too much drag when opening the faucet.
Or I just replace the whole faucet with a new one.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 06-12-2019, 03:50 AM   #257
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I think the teflon string was the rubbery messy stuff.
Went to our local plumbing supplier & they were out of the packing string.
I'll try ACE tonight.
David i just can get a new faucet. The old shower faucet is too cool to let go.
Old 06-13-2019, 05:14 PM   #258
Central , Mississippi
Today is the day.
I tried the various strings without much luck. I gave up and used a cone shaped rubber seal and finally got the old faucet to seal. I think mine might be missing a washer to compress the new string
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-14-2019, 03:33 AM   #259
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Does your faucet have a dome shaped packing nut?
Mine does & I'm beginning to wonder if that is the problem.
I've read the domed shaped nuts require a dome shaped washer.
I'll work at it this weekend.
Thanks!
Old 06-14-2019, 08:03 PM   #260
Thanks!
Geez, a test I didn't study for. I had a dream last night I was back in history class and I had an exam I forgot to study for also.
If I recall, the nuts were an inverted cone on the back and the packing rope simply jammed between it and the shafts jack screws. Mechanically it didn't make sense and I wrote it off a prior owner fixes. If I tightened the nut to the point of not leaking, the valve wouldn't open much for flow. I suspect the assembly should have been nut, gland string, washer, fixture all fitted over the shaft. Without the washer nothing would seal.
Old 06-15-2019, 12:35 AM   #261
jcarp sculptor
1966 22' Safari
portland , Oregon
Ready to install new sub floor but dont have old pattern to cut from....
Does anyone have a curved pattern cut for 66 safari they can send?????
I am in Portland Oregon..... never done anything like this.....
Anyone in the community that has the curve pattern for 66 safari subfloor?
suggestions on how to proceed.????
jCarp
jcarp is offline   Reply With Quote
Old 06-15-2019, 06:00 AM   #262
1966 22' Safari
Fredericksburg , Texas
jCarp
jcarp, you may get better results if you start a separate thread on the subject. Ours is 22.5” radius. Let me know if you need more since they all vary. Good luck
Bubba L is offline   Reply With Quote
Old 06-16-2019, 11:42 AM   #263
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
The old faucet is now leak free. 😁
I ended up using a couple of inches, maybe less of the fat kind of graphite & oil impregnated string..from Ace. Not the rubbery stuff.
Used a dental tool to push it down flush into the fixture.
Then I had some beveled yellow rubber washers. Those I drilled out to fit the valve shaft.... Extreme press fit.
The washers were pushed down over the shaft then the nut snugged down.
Thanks for the tips.....
Happy Sunday.
Old 06-16-2019, 06:53 PM   #264
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Yea! Clap, clap, clap. There is nothing like being leak free. David
WBCCI #8607
VAC Region 11
Today is the day! DJCJ 76 AIR Member Introductions 12 07-20-2010 12:18 PM
RV Story in USA Today--Today SteSpot On The Road... 0 05-18-2009 02:14 PM
Today's today, You know what that means? codybear Off Topic Forum 20 11-08-2006 11:31 PM
South Today's the day for generator questions Minnie's Mate Boondocking 15 11-01-2006 06:11 AM
today's the day! bradk Our Community 31 04-21-2006 08:28 PM
